crawford plenum problem
Old Sep 1, 2006 | 06:14 PM
Jeff92se's Avatar
Red Card Crew
Or do the gasket in two sections and put silicone gasket sealer on the edges.
But IMHO the oem gasket is alot sturdier than the run of the mill gasket material at the store.
Old Sep 2, 2006 | 07:15 AM
jimmyc13's Avatar
I think paying $30 for the OEM gasket is a helluva lot easier than cutting one by hand. Just MHO. Wow, that sucks that you had to go thru that w/ your plenum. Also not sure why they didn't recommend using a gasket!
Old Sep 5, 2006 | 04:42 PM
dmsteele92831's Avatar
Leak on Plenum
If you have a vacuum leak will there just be a hissing sound or can you feel the air? Will it throw a cel eventually?
Old Sep 5, 2006 | 04:47 PM
Jeff92se's Avatar
Red Card Crew
If you have a vacuum leak, it will sound like a tea pot coming to boil. That is if you have that whistling thingie on it. "eeeeeeeeeeeeeeeeeeeeeeeeee" is about the right sound. Don't ask how I know
Old Sep 5, 2006 | 06:15 PM
1fastsedan's Avatar
i found the leak alright, i went and purchased a new gasket and bolted in on yesterday. the plenum problem has been fixed. but i have an idle problem. its idleing around 1000.
Old Sep 8, 2006 | 12:40 AM
G SEDAN's Avatar
i had a leak and also a rough idle, im going to try the gasket and see if the idle problem will go away with that. SES light also came on, but im sure that will go away.
Old Sep 8, 2006 | 12:19 PM
1fastsedan's Avatar
i had to use two gaskets and the problem was fixed, my light came on because i unplugged and cleaned my throttle body it threw a code, so i used the 12hr disconnect and everything is back to normal.
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
Jnm07
Sep 5, 2015 01:16 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
kevintandmd
Sep 3, 2015 06:41 PM
Julianpnce
Intake & Exhaust
Sep 1, 2015 07:41 PM
