plenium question
Old Sep 2, 2006 | 01:24 AM
logik05se's Avatar
plenium question
i knwo i know, i did search this and found almost my answer but not exactly.
when i look at the diff products i see the crawford is a lower plenium and the mrev is an upper plenium...what exactly is the diference and can both of these be used then since one is upper and one is lower?
no0b, i know.
Old Sep 2, 2006 | 03:24 AM
Triji's Avatar
You got those reversed bro... Go to the Crawford website and read and watch the video there to learn smething...
Old Sep 2, 2006 | 04:04 AM
imalazeeass's Avatar
btw, its PLENUM
Old Sep 2, 2006 | 04:44 AM
abcquackyxyz's Avatar
haha a guy at a performance shop kept on say plentum and the whole time there i was correcting him over and over.. but yeah its plenum.
Old Sep 2, 2006 | 05:13 AM
truplay8's Avatar
THE BATMOBILE
yea its def plenum and check www.crawfordz.com and watch the video that explains everything
Old Sep 2, 2006 | 08:54 AM
bigd23's Avatar
Anyone notice Infiniti is spelled wrong in the first sentence on that site?
Old Sep 2, 2006 | 09:58 AM
logik05se's Avatar
i just read up again....the mrev it says it a lower collector and the crawford says its the upper plenum. I still havnt watched the vid because im at work so im guessing that is def the answer..
Old Sep 2, 2006 | 10:40 AM
DannoG35's Avatar
MD also offers a plenum spacer that can be added below your crawford or stock set up. You just need to watch out for what size spacer you get. I recomment the MD 3/8 spacer. I have heard good things about the Mrev and Mrev II. Tony from MD is a good guy.
Old Sep 2, 2006 | 07:28 PM
logik05se's Avatar
ok so i watched the video and now have an idea about what a plenum* does....but still whats the diference then between that and the mrev?
and why does the polished crawford cost twice as much as the black one?
Old Sep 2, 2006 | 07:33 PM
it is polished. the other is casted. polish gives a smooth surface air travels a lot smoother. the plenum is the top piece of the manifold.
Old Sep 2, 2006 | 07:43 PM
logik05se's Avatar
ok thats what i thought....so they should be able to be used in conjunction with eachother correct?
Old Sep 2, 2006 | 07:48 PM
black6mt06's Avatar
CHECK OUT SKUNK2 - The Best
Old Sep 2, 2006 | 08:00 PM
^ how is that skunk 2 spacer?
Old Sep 2, 2006 | 08:59 PM
logik05se's Avatar
to me that sounds like marketing bs....air isnt a solid, the microscopic size bumpbs that cause the ruffness on the ceramic cant possible make air travel any different.
Old Sep 15, 2006 | 01:49 PM
Jeff92se's Avatar
Red Card Crew
Actually there is theories indicating a slightly bumpy surface is actually better for flow. Air molecules adhere to the rough surface and create a boundary layer of air that helps "lubricate" the air that follows it.
