Header Installation Difficulty
Old Nov 14, 2006 | 04:25 PM
MJ_G_35's Avatar
^ +1
Originally Posted by G352NV
if you know what your doing.
Old Jan 6, 2007 | 07:28 PM
jdmeg21's Avatar
no one has done a DIY for this. I don't daily drive my car. So I guess when I get my headers I'll do the DIY for you guys. Shoot I've done everything else by myself. even swapped a motor on my other car.
Old Jan 6, 2007 | 09:12 PM
wilksoner's Avatar
not somthing u want to do on ur own pay someone i can only imagine how long it would take without a lift
Old Jan 6, 2007 | 10:31 PM
jdmeg21's Avatar
lift as in engine hoist to lift the motor or lift as in complete car lift to get under.
Old Feb 8, 2007 | 01:51 AM
RRG35's Avatar
go to drift speed they charge me $240 to installed my DC headers. Very good people.
Old Feb 8, 2007 | 12:31 PM
JC79G35's Avatar
Keep in mind it also depends on the Headers. I hear the Crawford ones are the most involved according to their instructions online. The Stillen ones, which are similar to the Nismo/DC Sports variety are a little easier and (according to Stillen's instructions) only require the installation and removal of the header throught the bottom of the car.
Old Feb 8, 2007 | 12:35 PM
SWATSON's Avatar
The shop that uninstalled all my mods before I sold the car was able to uninstall my headers without a life. I'm sure it's possible w/o a lift, but it'll be a b!tch for sure!
EDIT: I had Strup headers....
I'm pretty sure the engine has to be pulled or nearly pulled for the Crawfords
Old Feb 8, 2007 | 01:00 PM
wilksoner's Avatar
my shop said it was an 8 hr job and the guy that did them told me after it was a b*tch to do
Old Feb 8, 2007 | 01:32 PM
Jee_35's Avatar
depends, the Strup Headers does NOT need a lift, and the gains are real nice. You should definitely check them out in the marketplace, I belive partshipperdave sells them.
Old Feb 8, 2007 | 01:36 PM
b00stedjustin's Avatar
Originally Posted by Jining
My buddy knows quite a bit built his own motor (240sx) etc so he could do it for me. He just wants to know if its physically possible without a lift.
not unless you are super duper skinny. Of course you will need a lift.
Old Feb 10, 2007 | 04:34 PM
partshipperdave's Avatar
hey guys - yes, ideally, you would want to do this install using a lift, so you can comfortably get under the car to get at all the bolts, and be able to easily move aroud under there. It is a tight fit, and getting at some of those header bolts can be a real bitch - knuckle busting if you're not careful.
If you don't have air tools, you're best friend will be the racheting box wrenches - you'll want to definitely get one in 14mm size, since that's the size bolts holding the OEM manifolds on the block. But I'd recommend getting a set of them, have at least 10mm, 12mm, and 14mm sizes at your disposal.
You can do this job on jack stands, but it'll just be more difficult and time consumming, as you'll spend a lot of your time under the car. Get yourself a tool jockey so you don't need to keep climbing out to get the next tool you want!
Yes, we do sell the Strup headers, and have them going for only $479.95 with free shipping! The Strup headers do NOT require you to lift the engine or lower the tranny in order to install them. And they come complete with the hardware you'll need and step by step instructions. It's not an easy job, but there are proven gains to be had by doing this mod, and as many people have come to discover with the VQ35 engines, it's hard to get any serious gains without Forced Induction!
11bEMT
May 27, 2022 03:13 PM
linedr89
Aug 17, 2015 05:11 PM
yosip1115
Engine - Exhaust
Jul 22, 2015 01:47 PM
