Ztube and Pop Charger Question
i did just the pop charger with heat shield over the weekend and it
sounded good, had better breathing up high... almost reminded me of
vtec at 5800rpm+.
today, i picked up a used Z-tube for $30 at www.ultimatez.com,
installed it, and took her out for a spin. mid-band torque gain is
noticibly higher with a nice grunt. i lost torque down low... like
crawling up a driveway is now a little bit of challenge for the motor.
Did not affect drivability at all in normal driving.
nice mod for less than $150.
i suggest you check with the 350z
clubs and stores for a used z-tube. no sense buying a new one for $70+.
vtec at 5800rpm+.
i suggest you check with the 350zclubs and stores for a used z-tube. no sense buying a new one for $70+.
Originally Posted by aHero4Eternity
i have my doubts that going up a driveway is harder for your motor now..
i could be wrong..but i have my doubts..
well, it needs more rpm than 1200rpm to pull up now where as before,
i could just tap the gas and half-clutch to crawl into my garage. i know
my own driveway and car... dood.
hey guys, i got my popcharger from a buddy of mine but he didn't have the metal bracket that holds the popcharger in place.
1.) Is it detrimental to not have that piece of metal bracket holding up the air filter?
2.) If it is detrimental, where can I get that piece individually?
3.) Does anyone know what bolts and washers I need to hold the heatshield in place to the MAF? I think my friend lost that too. If someone can tell me, I can just go to hardware store and pick it up.
4.) Does anyone know what washer and bolt I need to hold the MAF sensor housing in place to the air filter? My friend lost that too and I'm currently using the stock bolts. They don't fit all the way into the air filter metal piece because the stock bolt is too long. Anyone know what size?
Thanks guys =)
Thanks guys =)
Originally Posted by BadBoy06
Metal parts always = heat soak
Originally Posted by SuperShick
anyone know the answer to my questions?
baker2795
Sep 2, 2015 06:00 PM
