difference b/w test pipes and hfc
Old Oct 11, 2006 | 09:00 PM
G35_sylvi's Avatar
very noobie question... but...
what is the difference b/w hfc and tp... i looked at a pic of the coupes underbody and i can't tell where you would install both of them... or are they just interchangeable and its just preference which you want to buy and install...
what's the difference?
Old Oct 11, 2006 | 09:03 PM
overdrve's Avatar
hfcs replace regular cats. test pipes replace cats so you can run cat-less. not legal though...
Old Oct 11, 2006 | 10:49 PM
Calvin's Avatar
Overglorified Altima
neither high flow cats nor test pipes are legal. you cant touch your stock cats until haver 80k miles or something.
high flow cats should not throw a CEL (check engine light), should not rasp, and have a possible chance at passing smog.
there are non resonated test pipes and resonated test pipes. of test pipes and high flow cats, test pipes will yield better gains. however, if you have an 04.5 or later g (i think that was the year) then you might throw a CEL, easily fixed with non foulers. non resonated test pipes are cheaper (in price) but will rasp like a ****. resonated test pipes are suppose to get rid of most rasp. ive heard the fast intention resonated test pipes eliminate all rasp. down side to test pipes is you will never pass smog, you will get a headache from the gas odor, and you might throw a CEL.
i myself opted for fast intentions high flow cats. mainly because theres a little more luxury at the cost of a few ponies. no gas odors, no non foulers, and a possible chance at passing smog.
Old Oct 12, 2006 | 12:03 AM
BigShow's Avatar
dam after reading that post i dont see that its even worth it..what gains would u get from HFC? 10 hp and better sound?
Old Oct 12, 2006 | 01:15 AM
driftGT350's Avatar
i was planning on getting HFC soon... but dun got the monnnnaaaaaaaaay..... like mike yeung!
Old Oct 12, 2006 | 01:39 AM
Calvin's Avatar
gains depend on every car. but you can expect roughly around 8-10whp realistically id say
Old Oct 12, 2006 | 01:55 AM
suicidal2af's Avatar
On a forced induction car, maybe. On an NA, expect 2-3bhp.
Old Oct 12, 2006 | 02:20 AM
Calvin's Avatar
: test pipes give you gains all throughout the range
: probably like 10-15whp
: from independant dynos
: imo, most g and z owners will suffice with the stock exhaust
: just change the cats and y-pipe and it's more than enough for most cars
with HFCs...
: you'll notice a power gain though, that's for sure
: i think mostly low end and little high end
^^all that is quoted from my friend at nismo
Old Oct 12, 2006 | 12:16 PM
Ralph0064's Avatar
How was the sound output from your high flow-cats, ahero4Eternity. Im assuming your running stock exhaust? was it a HUGE change, or just a slightly louder tone.
Old Oct 12, 2006 | 02:15 PM
Calvin's Avatar
^^dont have them installed yet
G35VSHNG37
Oct 25, 2015 08:43 PM
nickmcc123
Aug 20, 2015 03:10 PM
Ray Feta
Aug 13, 2015 11:40 PM
Black_Out
Intake & Exhaust
16
Aug 1, 2015 08:44 PM
