exhaust note changed after reset
Old Oct 25, 2006 | 12:56 AM
diablo1356's Avatar
ok i know it sounds weird..maybe im imagining it but after i recet my ecu (overnight battery terminal removal)..the stock exhaust sounds a little different...doesnt sound as throaty and doesnt sound the same in the higher revs...anyone know what it could be?...my sig isnt updated..i put the stock ex back on and i have everything else..its kinda weird
Old Oct 25, 2006 | 01:11 AM
DaveB's Avatar
You're not imagining it. After a reset, the ECU uses a preset air/fuel and ignition map. These maps lean on the conservative side which the A/Fs are rich and the ignition is dialed back a bit until the ECU learns over the period of about 30 to 40 runs. You will probably notice worse MPGs and reduced performance in the short term along with boggy tip-in throttle performance and reduced induction noise.
Old Oct 25, 2006 | 01:32 AM
Diamond G35's Avatar
^^^^ what he said
Old Oct 25, 2006 | 06:02 PM
diablo1356's Avatar
so it will go back to the way it ways after some time right?..i always thought reseting the ecu was good for performance reasons...like it runs as if the car already had the boltons...
Old Oct 25, 2006 | 06:25 PM
diablo1356's Avatar
bump..just wanna make sure it will return back to the way it originally was..
Old Oct 25, 2006 | 08:04 PM
stpdevil's Avatar
What DaveB said is correct. The ecu will set itself back up again. Its a quite common misconception that reseting the ecu somehow gives you more performance or that your car can get into "granny mode" if you drive it slowly. The only time a ecu reset might be helpful is if you just added a mod that changes your a/f ratio. In this case, the car will def learn to set itself correctly, but reseting the ecu might help it do it a little quicker.
Theres really no reason for you to ever reset your ecu if you haven't done anything to your car and theres nothing wrong with it. Nothing to worry about though.
Old Oct 25, 2006 | 08:16 PM
diablo1356's Avatar
wouldnt putting my stock exhaust back on change my af ratio?...
Daniel k.
Nov 3, 2015 09:52 AM
wuppiedog
Aug 7, 2015 11:16 AM
Mac8008
Aug 4, 2015 09:19 PM
kenthung
Jul 21, 2015 05:56 AM
