Which Spacer Should I Get!
Old Nov 1, 2006 | 08:47 PM
kennyz424's Avatar
http://infinitipa.zoovy.com/category/engineupgrades
^ Which woiuld be the best for me to choose and why...
Old Nov 1, 2006 | 11:38 PM
kennyz424's Avatar
BUMP! cmon guys i dont understand the differene between them
Old Nov 1, 2006 | 11:42 PM
ttrank's Avatar
Grocery getter
Motordyne 5/16" isothermal if you want to keep your engine cover.
1/2" if you are willing to keep it off and I would, all it does is keep heat in.
If you want more info read around on their site. Motordyneengineering.com
bikesbikes's Avatar
I have the 5/16" copper isothemal spacer and i'm happy with the results. I think you might get more power with the 1/2" spacer but I don't think there's a huge difference unless you go FI.
Old Nov 1, 2006 | 11:44 PM
filanj's Avatar
if you are going to get one, get the 1/2... it is dyno proven to get the most hp out of our cars compaired to kinetix, crawford, etc... look on the motordyne website and you'll see clearly
Old Nov 1, 2006 | 11:45 PM
filanj's Avatar
just a couple ponys... if you get it tuned there will be a big diff but black's prolly far from that
Old Nov 1, 2006 | 11:46 PM
Calvin's Avatar
Overglorified Altima
unless you plan on tracking your car then get the 5/16
it lets you keep the engine cover and will yield gains throughout
whereas the 1/2 wont let you use the engine cover and may rob you some down low but youll gain it all back and more up top
the difference in gains is really not all that much imo
unless you track your car then i guess thats when every bit counts
Old Nov 1, 2006 | 11:49 PM
filanj's Avatar
I'm not quite sure why so many people worry about the engine cover being on... It takes a half hour or less to remove a spacer and put the car back to stock if you need to take it into a dealer
Old Nov 1, 2006 | 11:52 PM
kennyz424's Avatar
anyone have pictures of how our car look under the hood without the engine cover one...plz!!!!!!!
Old Nov 2, 2006 | 12:02 AM
Calvin's Avatar
i just like the look of the engine cover
Old Nov 2, 2006 | 12:03 AM
Calvin's Avatar
take it off yourself and see for youself
all you need is a 10mm and remove all 4 bolts
takes like a minute
Old Nov 2, 2006 | 12:15 AM
kennyz424's Avatar
lolol i would if i had my car haha i dorm at school right now and dont currently have my car with me any1 have a pic for me plz so i can decide which spacer to get
Old Nov 2, 2006 | 12:16 AM
kennyz424's Avatar
also i just read i can keep my engine cover...
Motordyne 1/2" Basic Spacer
This stealth modification adds 12HP-14HP and is the simplest to install. The engine cover easily fits and never needs to be cut. With the engine cover in place the engine bay looks completely stock.
and ...
Motordyne 5/16" Basic Spacer
This stealth modification adds 11HP-13HP and is the simplest to install. The engine cover easily fits and never needs to be cut. With the engine cover in place the engine bay looks completely stock.
I guess i can keep my engine cover for the 1/2 correct?
Old Nov 2, 2006 | 12:20 AM
JDM 350GT's Avatar
Motordyne!!! All The Way!!!
Old Nov 2, 2006 | 12:23 AM
AthensBlueG's Avatar
Brian
The 1/2" is too thick for you to be able to keep your engine cover on. It won't fit under the hood. The 5/16" WILL fit though.
