Filter Options for Stillen Intake?
Old Dec 5, 2006 | 11:22 PM
vt_maverick's Avatar
Question Filter Options for Stillen Intake?
I'm thinking of getting the Stillen intake but I have one concern: I'm not a fan of the oil type filters. I believe that the cone filter suppplied with the Stillen intake is a K&N oil type filter (please correct me if I'm wrong here), but I'm wondering if Amsoil (or anybody else) makes a non-oil based filter that can be used instead.
Anybody have any info? TIA
Old Dec 5, 2006 | 11:28 PM
ttrank's Avatar
Grocery getter
Changed mine to an AEM dryflow.
Old Dec 6, 2006 | 12:27 AM
Got a part number? When you were researching an alternate filter did you come across any other brands that would work? Thx
Old Dec 6, 2006 | 09:29 AM
Anybody know if there are performance differences between the standard filter and alternative options? Does Stillen recommend against using a different filter?
Old Dec 6, 2006 | 09:50 AM
ttrank's Avatar
Grocery getter
I don't have a PN, just got it by size and my receipt doesn't say. I don't remember the length but the hole is 6". It was only ~$39 shipped.
Old Dec 6, 2006 | 09:59 AM
Do you know the Stillen (K&N?) filter part number? If I could figure that out then I could cross-reference it against other filters...
Old Dec 6, 2006 | 10:52 AM
BayAreaRefuGz's Avatar
i fly low
does it still have that deep tone? what's wrong with the oil-based filters?
Old Dec 6, 2006 | 11:11 AM
I'd just prefer not to have to mess with cleaning it and oiling it. Theoretically you can mess up your MAF sensor if you over-oil it, although I know a lot of people will chime in and say that's pretty rare.
In most cases the nanofiber filters work just as good or better than the oiled filters, and only require a dry cloth to clean. They're also generally the same price or cheaper than the oil-based filters.
Old Dec 6, 2006 | 04:28 PM
i fly low
well i purchased a stillen cai with ztube. it should be coming in this week. does it come with oil? is the filter already oiled?
Old Dec 6, 2006 | 05:09 PM
Q45tech's Avatar
If you measure every filtration medium in the correct [square inch area including the pleat depth*] under the maximum air flow conditions for the engine [ ci/2 x rpm x VE/1728] you will find less than 3/4 of 1 percent variation across oem to any aftermarket.
A 214 ci engine can only consume a set amount ~~ 325 CFM at best.
* iron flat [mash the pleats flat] every sample and measure the area you will be surprised that oem has a larger area than aftermarket,
Old Dec 6, 2006 | 08:55 PM
fortified's Avatar
Well, not quite. With the Amsoil nanofiber you use low pressure shop air from the inside to clean, no oil, reinstall.
The AEM need a liquid bath cleaner similar to K&N, then let dry out, no oil.
Old Dec 6, 2006 | 09:03 PM
i fly low
whoa..nice information. did you go to a Filter School or something? i'm not clowning tho.
so youre saying that the OEM intake/filters have better performance than an aftermarket intake?
Old Dec 6, 2006 | 10:11 PM
Glex25's Avatar
Administrator
Stillen Replacement Filter part number directly from Stillen
402960L
Old Dec 6, 2006 | 11:42 PM
So then what is the point in aftermarket filters whatsoever?
Btw, checked Stillen's website today and it says "Comprised of a high-quality polyurethane intake port, washable and reusable cotton filter element, and STILLEN's signature Aluminum Venturi Ring, the Intake draws air from outside the engine bay."
So apparently it's not an oiled filter. So now the question becomes: is there any reason to use another filter at all?
Old Dec 7, 2006 | 04:12 AM
i fly low
what's so special about the ring on the stillen CAI?
