problem with water in CAI suggestions please
Old Dec 20, 2006 | 04:24 PM
infinitialex's Avatar
I got a CAI in my 03 g3 sadan, It sits right under the left headlight in the engine bay. What i didnt realize until today that water from rain might be around that area and might get sucked into the intake.
I opened the hood today after driving in the rain for 30 minutes or so and there is dropes of water i can see around the intake area, so im sure some water is geting into the intake. Anyone else has an intake in the same location with similar problems??? How bad is this?
Old Dec 20, 2006 | 07:29 PM
anyone?
Old Dec 20, 2006 | 07:39 PM
CrazyRuskie's Avatar
Droplets of water won't do any harm. The harm will be done if your intake gets submerged in water and the intake sucks in a decent amount causing the engine to hydrolock. Droplets of water will just evaporate
Old Dec 20, 2006 | 07:43 PM
well my intake sits right behind the headlight so during hard rain some water gets that way,,i dont think its big amount but still wondering if this is bad for the car.
Old Dec 20, 2006 | 07:44 PM
Everyone w/ a CAI has it sitting in the same spot with the G . It won't be a problem unless you drive into a puddle big enough to submerge the filter and suck in a lot of water.
Old Dec 20, 2006 | 09:13 PM
well before my intake set lower under the headlight inside the bumper cover but i didnt like that location ,,it was too low plus a lot of dirt was geting in, so i modified it but now the freaking water
Old Dec 20, 2006 | 09:19 PM
GThIrtYFiZle's Avatar
Dont worry about it. As long as you dont drive like a maniac when it rains you should be fine. The only time you will have a problem is like others said if you submerge the whole thing under water. If you are ever driving in rain and you have doubts about a puddle dont ever risk it and if you have to just drive very slow and keep your rpms below 2500 almost not pressing on the gas. If you are stll worried just get a by-pass valve, that will should work, at least it did for me. I know sleep better at night.
Old Dec 20, 2006 | 09:23 PM
well im not worying about puddles but jsut about rain geting thruegh the grill, around the headlight area and where water drains between fender and teh hood....
Old Dec 21, 2006 | 02:28 AM
G35 tycoon's Avatar
try to find a bypass valve for ur intake setup..should help a lil bit
Old Dec 25, 2006 | 02:15 PM
ISMSOLUTIONS's Avatar
^^+1 bump for Tycoon...
It sounds like your worried about things that haven't happened yet, and from MANY sources and threads on this site, something you should worry about onky if the filter is submerged.
Do the valve - it'll give you peace of mind...
Rick
chinee
Jun 10, 2024 07:48 PM
mike730
Jan 12, 2018 04:25 PM
Kng0fHrts
Sep 15, 2015 05:40 PM
Smittie20
Aug 9, 2015 04:29 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
