is this a ground?
Old Jan 4, 2007 | 02:43 PM
Otacon132's Avatar
is this a ground?
i just had my exhaust installed, and took a look under the car, i found this wire dangling....i believe this just bolts onto the exhaust bolts, am i right?
Old Jan 4, 2007 | 02:52 PM
cato's Avatar
SouthernComfort Moderator
You are correct. This was originally attached to one of the bolts holding the mid-pipe and the muffler togeather.
Old Jan 4, 2007 | 02:54 PM
Calvin's Avatar
Overglorified Altima
yep, just a ground.
man...that's one fugly exhaust...!
Old Jan 4, 2007 | 02:55 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
yes that's a ground and it's supposed to be attatched to the hole on the exhaust right above it. There should have been a bolt and some nuts that came with the exhaust to bolt that ground wire on, that's how it was on the HKS i previously installed.
-GP-
Old Jan 4, 2007 | 03:51 PM
speedgeek's Avatar
I would find some way of grounding that to your exhaust, it will help your 02 sensors monitor more efficiently
Old Jan 5, 2007 | 03:23 AM
StVincent's Avatar
Originally Posted by aHero4Eternity
yep, just a ground.
yep, HKS Ti exhausts are fulgy as hell..
Marlin84
Apr 1, 2020 12:52 PM
prinny
Nov 22, 2015 11:07 PM
toadfire
Sep 21, 2015 07:15 AM
JustinMKN1
Sep 18, 2015 03:40 PM
