ECU reset works but...
Old Jan 23, 2007 | 10:44 PM
TaiPan's Avatar
I installed a Stillen intake with Z tube, MREV2, DC Sports headers and Crawford HF cats recently on my '04 G35 5AT coupe. The results are very good but I've got a "service engine soon" light. The pedal method ECU reset works (per the MREV2 procedure) but the ses light comes on again after a minute or so.
Is there a "break in" time for these mods? I have a great mechanic who services my SC'd GSR so I know the install was done right. He's going to research the problem but I thought I'd look for some input here.
I've got about 250 miles on it since the upgrade. Any ideas?
TIA for suggestions.
BTW, with these mods and the stock exhaust it's very quiet. Until you put the foot to it. Then it turns heads. Very nice.
Old Jan 23, 2007 | 10:46 PM
Calvin's Avatar
Overglorified Altima
are the crawford cats new or used?
Old Jan 23, 2007 | 10:51 PM
TaiPan's Avatar
Brand new. Fast delivery, they're 90 miles from here.
All of the mods are new.
Old Jan 23, 2007 | 10:53 PM
Calvin's Avatar
if this were me and i had no other ideas i would try the non fouler mod
but i have no idea
hope it all works out for yah
Old Jan 23, 2007 | 10:55 PM
TaiPan's Avatar
Non fouler mod? Pardon my ignorance. What's that?
Old Jan 23, 2007 | 10:57 PM
filanj's Avatar
my first thought was a leak somewhere, but I could be wrong. have you run it through a decoder?
Old Jan 23, 2007 | 10:58 PM
ttrank's Avatar
Grocery getter
Go to a local parts store and have them run the code.
Old Jan 23, 2007 | 11:29 PM
AboostedG's Avatar
Foulers... They're 18mm long Tapered.
Old Jan 24, 2007 | 02:43 AM
Hydrazine's Avatar
There is also a small harness plug on the back bracket connected to the upper plenum. If its not connected it will produce thoes same symptoms.
If that's not it, try to find out exactly what the code is. It will help troubleshooting a lot.
Old Jan 24, 2007 | 12:17 PM
ISMSOLUTIONS's Avatar
+1 for Tony!!!
Also - you should verify that everything is installed properly. Tight conenction, re-torque bolt where needed. You could have an intake leak. Also, you can try, with the battery disconnected, to unplug and MAF sensor and replug it in, then reconnect the battery and see what happens.
I have never known a Crawford CAT to cause a CEL - in fact, I don't know of any CAT that causes one...to my knowledge, so the non-fouler is likely not the issue.
Check the O2 sensors - maybe not tight or a wire got messed up.
Rick
Old Jan 24, 2007 | 08:55 PM
TaiPan's Avatar
Thanks for the input, guys.
I'll have my mechanic take a look at everything mentioned in the replies. He's a great guy and this is his first shot at a G. I'm sure that one of your solutions will work.
I'm on travel now but I'll have things checked when I get back.
Once again, thanks for all the suggestions. As soon as we get it figured out, I'll post the fix.
Old Jan 24, 2007 | 09:10 PM
Where are you located?
Old Jan 31, 2007 | 10:11 PM
TaiPan's Avatar
Update
The codes indicate that the MAF sensor is having a problem with the air temperature reading and another related to the exhaust. I'm waiting for an email with the exact codes but I'd guess that a bad air temp reading would cause an exhaust error due to an incorrect fuel/air mixture.
A leak check indicated no problems.
My mechanic, Art, called about the Mrev2 and got some excellent support that sort of pointed to a possible problem with the Stillen intake and z tube. They said it was possible that, because it was new, excess oil on the filter might have fouled the MAF sensor. A check indicated it was ok.
Stillen was another matter. They refused to provide tech support unless Art provided information on where the intake was purchased as well as other info. Then they said something about buying from unauthorized vendors. What a load of crap! Absolutely NO help. You might even find that intake for sale here shortly so I can replace it with something else.
Art wants to replace the original intake (with K&N drop in) to see if that fixes the problem but as luck would have it, I've got to travel again Sunday.
I'll post again when I get back and Dr. Art has his way with the car.
BTW, I'm in north Alabama.
Hasanbaloch
Feb 29, 2024 08:45 PM
mike730
Jan 12, 2018 04:25 PM
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
kenthung
Jul 21, 2015 05:56 AM
