Will 350z pop charger fit g35?
Old Mar 29, 2007 | 09:55 PM
kako's Avatar
Originally Posted by lowrider
The hole is a fitting for the internal hood scoop on the leading edge above the raditor. It allows air from the hood scoop to feed the PopCharger. Check out this old pict to see.
Lou
thanks for the picture. So will it not work as good without allowing the air to feed in ? Should I worry about making the hole ?
Old Mar 30, 2007 | 11:37 AM
lowrider's Avatar
Well, as well as the hole, the heat shield also comes with that rubber shield and gasket that attaches to the hole on the shield and fits over the end of the plastic air scoop.
Lou
Old Mar 30, 2007 | 01:02 PM
kako's Avatar
Thanks for the responses but I'm still unclear as in what happens using the 350z heatshield which basically blocks the air scoop ?
Old Mar 30, 2007 | 02:23 PM
lowrider's Avatar
This is my opinion. The 350Z has outside air coming from the front of the filter. The G35 has outside air coming from the front of the radiator to the left of the filter. IMO, if you put the 350Z heatshield on, you will not be getting any outside air, just hot underhood air. Again, this is my opinion, for what it's worth.
Lou
Old Apr 3, 2007 | 11:00 AM
chinaman_87's Avatar
I also bought a popcharger from a 350z member but I didn't get the shield and I haven't had any problems.
Old Aug 4, 2015 | 03:02 PM
vitamin.v's Avatar
I just bought one off a 350z member as well and didn't realize this until now. I was wondering if i can just cut a hole in the heatsheild and then extend a peice of rubber to equal the diameter of the front air duct on the right side to feed the air to the popcharger?
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
laksjd84
Jul 24, 2015 05:12 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
