After headers and test pipes being installed....
Old Mar 14, 2007 | 06:50 PM
G-Ride Canada's Avatar
Unhappy After headers and test pipes being installed....
there's a problem been a bug to me, after installed the parts, i think in the mid section of my exhaust system, could be the section between test pipe and below, there's noise like air leaking out with fast ticking sound, but my rpm doesn't seem to act weird...could it be because the stock muffler or exhaust system isn't good enough any more for the hp that im boosting out?
i can hear the sound very clear as im reving over 3000.
please help me out. thanks
Old Mar 14, 2007 | 06:56 PM
MixturePinoy's Avatar
hmmm... sounds strange, when I purchased my cheapo ebay testpipes they leaked, and they made a sound like someone with a lisp trying to whistle. the ticking sound could be the debris that is built up from the packaging that is burning up. as far as the exhaust, there's plenty of folks on here with that setup and no problems. you should check all your gaskets and bolts to see if everything is tightend properly.
Old Mar 14, 2007 | 07:12 PM
but it's funny, cuz when i put it to neutral, and rev up, the sound isn't as clear?
Old Mar 14, 2007 | 07:20 PM
NJlakeshoreG's Avatar
u might be pinging..or maybe even low on oil...u never know..check it out mang!
Old Mar 14, 2007 | 07:29 PM
duggy's Avatar
It's obvious that you have a leak.
Old Mar 14, 2007 | 07:31 PM
hmmm... did you install everything yourself?
lol no wonder civic drivers were looking at me like I'm one of them...cuz it sound just like fart can
Old Mar 14, 2007 | 07:34 PM
lol
Dude, I'm sure you have a leak somewhere
Old Mar 14, 2007 | 07:36 PM
ya I have been questioning myself if there really is a leak, but i never got a chance to go check up....but thanks guys, now I really should go get it check out
Old Mar 14, 2007 | 07:37 PM
Hi-TechG35's Avatar
As everyone else said sounds like you have a leak or bad gasket.
Old Mar 14, 2007 | 07:40 PM
pretty sure I have a leak now, cuz i just went start the car and can hear air leaking out somewhere, can't be the gasket, cuz they are brand new
Old Mar 14, 2007 | 09:05 PM
trey.hutcheson's Avatar
I don't think you have a leak. I've had that sound for a while now, and I've been through 8 exhaust setups. 7 of those setups have had this sound.
I'm pretty sure it's because the tubing isn't lined up just right. The inner diameter of the various pipes might be the correct measurements, but if they alignment of the pipes is off by even a millimeter, the exhaust gases can make a hissing sound as they flow over the misaligned pipe edges.
Old Mar 15, 2007 | 03:14 AM
^ then what would be the solution?
thanks for your help
Old Mar 15, 2007 | 10:17 AM
I'm afraid I've never found a solution. I've just chosen to live with it.
Old Mar 15, 2007 | 11:04 AM
DaveB's Avatar
Trey is probably right. Some of the noise/hiss can also be coming from the significantly thinner walled tubing too. The OEM pipes have rather thick walls with a very heavy grade stainless. Most aftermarket exhausts use thin-walled aluminized steel and stainless.
If you think you have a leak, try this. Let the car and exhaust piping cool completely. Then start the car and place your hand in close proximity of all the catback exhaust joints. If you feel pulsating air at the joint, you have a leak. You should be able to lie on your back from the side of the car and access all the joints. There's no easy way to tell with headers and header to test pipe connection though because of the limited access unless you jack up and support the car.
FYI, just because the gaskets are new, doesn't mean they can't leak. A lot, and I mean a lot, of aftermarket exhausts have issues with the exhaust flanges sealing. The problem is because the flange is too thin and when the flange gets welded, the heat distorts the flange and the gasket can never adequately seal.
