Exhaust "fix it" ticket
Old Apr 19, 2007 | 02:42 AM
PSD G35's Avatar
So here I was driving my G around town the other day, when all of a sudden a cop pulls me over. When he approached the car, I told him I wasnt speeding, he said I was going thru my gears too fast. He took all my information, and 20 minutes later he handed me a "fix it" ticket...for my exhaust being too loud. He also said I had to show the CARB # to get the ticket removed.
I have a Stillen dual cat back exhaust. Stillen dual cat back exhaust does not have a CARB #. So what to do? The Stillen exhaust looks like the factory exhaust, so do I just show up and say its been changed out? Any suggestions will be appreciated.
Old Apr 19, 2007 | 02:45 AM
PsYcholG35's Avatar
Who me??? NAAAAAAA.
funny i have the exact same exhaust i got a ticket for the exact same thing about 2 months ago. Went to court payed 20$ to get my car inspected the guy said that the exhaust sound perfectly legal. Case got dismissed.
Old Apr 20, 2007 | 02:44 AM
PSD G35's Avatar
thanks for the reply, I am going to take the car as is to the court house and have them say the same. thanks for the reply.
Old Apr 20, 2007 | 03:18 AM
Klubbheads's Avatar
^if that does not work out, call ur local CHP office and tell them the situation and ask them to give u a California certified exhaust sound level check place. Go there and u should be at about 80dbs (legal limit is 94db). Get the certificate for free and get the ticket signed off. Make sure u have that certificate in ur car at all times.
Old Apr 20, 2007 | 01:47 PM
Q45tech's Avatar
Exhaust Noise Limits: California regulations contain a number of sections specifying permissible vehicle noise levels. The Bulletin advises that passenger car exhaust systems [Q9] that comply with the requirements of Section 1036(d)(1), 13 CCR are deemed to comply with Vehicle Code enforcement Sections 27150 and 27151, governing mufflers and exhaust system modifications. [Q10]. The exhaust noise provisions in 1036(d)(1) establish a limit of 95 dB(A) measured 20 inches from the exhaust pipe outlet with the engine operating in neutral, at a specified speed typically between 3000 and 5000 rpm (see regulations for details). [Q9]. Exhaust system modifications are permitted to increase noise above the level of original factory installed systems as long as the 95-decibel limit is not exceeded. [Q10].
Old Apr 20, 2007 | 04:04 PM
Klubbheads's Avatar
+1, they rev and hold the rpms at 4500 rpms for our cars to be exact.
Old Apr 20, 2007 | 04:32 PM
b00stedjustin's Avatar
There are quite a few tracks that will kick you out if your exhaust exceeds 95 decibels, so you wouldn't want a exhaust regardless of legality that is past the 95 db limit.
Old Apr 20, 2007 | 05:32 PM
Klubbheads's Avatar
No aftermarket exhaust is going to pass that 95db sound level. The only way to get it louder than that is to strait pipe the whole exhaust.
Old May 22, 2007 | 01:00 AM
PSD G35's Avatar
I finally took care of the fix it ticket...it was pretty easy. got the windshield replaced. I am not to thrilled about the work, scratching the paint in some not so obvious areas. I drove to the Police department and the officer looked at my windshield, and listened to my "stillen dual cat back exhaust" and it was all good. No noise test or anything. Woo Hoo...
Old May 22, 2007 | 02:00 AM
ttrank's Avatar
Grocery getter
There are many aftermarket exhausts that go past the 95dB level. I would bet some of the G ones would not pass.
Old May 22, 2007 | 02:40 AM
threatcon07's Avatar
Most aftermarket for the G exhausts average at about 85-95 db at the upper end of the rpm range. There are several that are louder than 95 db. (95 db for an exhaust is not very loud, I can guess that those loud aXX Harleys riding around hit over 100 easy). Sport Z Magazine tested DB on several of the exhausts, and the Stillen was under 95 db through the whole rpm range, so you should be fine.
Old May 24, 2007 | 01:12 PM
savefatkids's Avatar
is it supposd to be 95 db at idle? or when you rev it? i used a db meter on my exhaust and at idle im at 95db at wot im at 118db? so would me exhaust be legal?
Old May 24, 2007 | 02:01 PM
Calvin's Avatar
Overglorified Altima
hahaha i'm gonna go with no. but that's just a guess.
Old May 24, 2007 | 02:06 PM
you were "going through the gears to fast"? That's not illegal lol. What a dumb cop.
Terry_G35
May 9, 2020 01:39 AM
RA081024
Aug 18, 2015 07:03 AM
Terry_G35
Aug 4, 2015 02:38 PM
newg37
Jul 26, 2015 09:32 AM
edwinisdumb15
SOCAL Meetings & Events
Jul 24, 2015 04:56 PM
