Running Lean with mods
Old May 13, 2007 | 12:32 AM
speedgeek's Avatar
So I have Motordyne ISO Thermal MREV, FI 300Cell Metallic Cats, Strup Headers, and FI Intimidator Exhaust (on the way) – should I be concerned about running to lean. Will the ECU compensate?
Old May 13, 2007 | 01:14 AM
Andy2434's Avatar
You should be find at the moment. However, just to be on the safe side, I would put your car on the dyno and get a AFR reading after you install the new exhaust set-up.
Old May 14, 2007 | 10:24 AM
speedgeek's Avatar
Thanks, I'm going to datalog it today.
Old May 14, 2007 | 10:46 AM
ballisticus's Avatar
I had a similar setup prior to reflash and I was in the mid-14's for air/fuel. Not dangerously lean, but not optimal for power. I could also hear the tell-tale signs of leanness on decel in the exhaust popping etc. Technosquare took my dyno printout and dialed it right in at 13.2 Runs strong as hell now and just a smooth rumble upon decel with not a sign of popping or backfire.
Old May 14, 2007 | 10:51 AM
Nismo G's Avatar
I would say that you are running lean. Should look into a piggy back system of some kind...
-Sean
Old May 14, 2007 | 10:56 AM
speedgeek's Avatar
Once the COBB access port comes out, I'll be getting that. Sounds like a great device.
Old May 14, 2007 | 12:32 PM
speedgeek's Avatar
For now, will the stock ECU compensate (for safety)?
Old May 14, 2007 | 01:05 PM
Yes. But I would say you are at the fuel limit now. As long as you are not throwing a SES light, you're OK. Just not making as many ponies as you should for the mods you have.
Old May 14, 2007 | 01:36 PM
ttrank's Avatar
Grocery getter
You will be at the limit of safe with that set-up.
I would pick up a used Unichip or Utec from a member and get a re-tune. Not only will you gain some power but it will be safer.
Old May 14, 2007 | 02:34 PM
speedgeek's Avatar
Thanks Guys. Ya think it's worth waiting for the COBB Accessport or just get a Unichip?
Old May 16, 2007 | 02:26 PM
ttrank's Avatar
Grocery getter
Don't know enough on the COBB unit. I am always a fan of the dyno tune for your exact car and the Unichip will give you that. Maybe the COBB will too?
Old May 16, 2007 | 02:31 PM
Jeff92se's Avatar
Red Card Crew
I assume you will have to. Cobb is a upload device. So someone will need to generate a map after seeing what the customer's ign / a-f ratios are and upload them. Dyno tune is the only way.
I suppose you could tune it on your own if Cobb releases their tuner but I think that might be a dealer only feature.
Old May 16, 2007 | 05:58 PM
speedgeek's Avatar
Ahhh...decisions…decisions....well for now I'm waiting for the Fast Intentions Exhaust to hit my doorstep (WOOT!), while I’m enjoying that I'll keep researching and maybe in a few months and a few more dollars I’ll make a decision. Thanks for all the info
JMFeld02
Intake & Exhaust
Feb 25, 2016 07:50 PM
sick_sixspeed
Jul 21, 2015 01:59 PM
vstypicals
Jul 20, 2015 10:55 PM
realtalk21
Jul 20, 2015 09:07 AM
