Emission passing cats
Old May 27, 2007 | 03:47 AM
ChromiumBlue7's Avatar
Has anyone tried these cats. They say 50 state emissions passing. http://www.z1auto.com/prodmore.asp?m...ust&prodid=580
Old May 27, 2007 | 04:58 AM
ttrank's Avatar
Grocery getter
I think you would be safe with those. A few others should pass too like the Crawford and Kinetix ones.
Old May 27, 2007 | 07:36 PM
well i bought em last night so we'll find out.
Old May 28, 2007 | 03:08 AM
ISMSOLUTIONS's Avatar
50 state legal???
In Cali - we need OBDII cert'd CATS - none are made other than OEM.
Rick
Old May 28, 2007 | 05:11 PM
well it didnt say anywhere that it was carb certified either, and i thought thats what u needed to be legal in california. i guess i should be able to send them back if they dont pass an emissions test.
Old May 28, 2007 | 05:59 PM
Remember - testing is different all over the US. In some states, if there IS a CAT and it passes, your good enough, in others if it passes your good enough, and in Cali you have to pass a full visual and emissions.
Sometimes, emissions pass isn't enough. In Cali as well, a header, like DC Sport, with CARB approval - or a standard Vortech setup, are also CARB approved and therefore do not affect your smog test ability/consideration. But walk up to a test facility with non factory CATS, and you'll be denied the test as you'll fail visual.
One last note: some CATS have carb numbers on them, but the set of CATS are not CARB approved. A CARB number on a component doesn't mean it is fully CARB approved. The unit, including pipe diameter, etc. must all be approved as a unit.
Rick
seagrasser
May 3, 2022 09:43 AM
Crisci33
Jun 29, 2017 08:31 AM
magnetism80
Jan 27, 2016 12:57 PM
NJ6MT
Oct 9, 2015 05:02 PM
