Plastic Plenum
Old Jan 20, 2004 | 09:55 AM
cliverman's Avatar
Re: Plastic Plenum
When this thread was started, I had already made up my mind to buy a Crawford. Good bang for the buck. Now, I've decided to wait to see how this plenum works out. I spoke with a few fellow engineers and we all believe this will be a solid alternative. We've had similiar resin in our thermotron at up to 80-90 C. That's some serious heat.
Old Jan 20, 2004 | 06:07 PM
AirWarrior's Avatar
Re: Plastic Plenum
I may be wrong...but isn't it weather the Plastic Plenum can withstand the heat or not..but will it withstand long term heat... hours of driving but at steady lower heat rate... Does plastic have the same sinkrate as aluminum and steel?
I'm very curious as to how this will turn out...wanted to buy the crawford plenum too but looks a little raw around the edges...and not worth another 500 bucks to have it polished...
Old Jan 20, 2004 | 06:26 PM
GurgenPB's Avatar
Re: Plastic Plenum
The only thing I am worried about is this plenum warping at the mating surfaces with the lower plenum, and not that it will melt. If the mating surfaces warp and create a leak, which is not outside ofthe realm of possibilties with such a product - it woud be worthless. Yes, the Crawford does NOT look very sexy - but it does a VERY good job. Also, it is certainly NOT an option for the FI guys like myself - as the positive pressure from within will exacerbate the potential problem I mentioned here.
Also, we don't know what the acoustics are with this plenum. The thinner metal plate of the crawford plenum already allows for more of the engine sound to come through. Who knows if this plastic plenum will exhibit more of a problem in this regard. Who knows about the sound dampening effect of plastics vs. aluminum??
Gurgen
Old Jan 20, 2004 | 07:30 PM
Carlos3186's Avatar
Re: Plastic Plenum
well i believe the company is comming out with 2 different types of plenums. one for F/I and one for N/A the F/I one looks realy slick
<a href="mailto:Carlos3186@hotmail....otmail.com</a>
Old Jan 20, 2004 | 07:31 PM
Carlos3186's Avatar
Re: Plastic Plenum
check it out
Old Jan 20, 2004 | 07:41 PM
shunsuenli's Avatar
Re: Plastic Plenum
New Premium Performance Plenum
Form Crawford.
Applications: Nissan 350Z - Nissan Murano - Infiniti G35c - Infiniti G35s - Infiniti FX35
Price : UNDETERMINED
Original Plenum Core Charge : $200.00 (Refundable)
Using an newer design we have been able to raise the plenum ever so slightly higher. Power gains in our opinion will be minimal to none, but for looks it raises the bar entirely for the setup.
Another piece we are proud to add to our line-up. Prices to be announced soon.
http://www.crawfordzcar.com/
Old Jan 20, 2004 | 10:01 PM
GforceI's Avatar
G SQUAD
Re: Plastic Plenum
Huh?
booger's Avatar
Re: Plastic Plenum
that must be the FI plenum....I want one of them...very cool looking and looks like it will work much better....Are they coming out with both at the same time ?
Couldnt afford it when young...gonna play when Im old
Old Jan 21, 2004 | 01:50 AM
AirSplat's Avatar
Re: Plastic Plenum
Woah! Carlos! Where did you get that set up? That looks awesome! Looks like an american muscle car intake manifold. Tell me where I can get one of those!
'04 G35 6MT Ivory Pearl
K&N Drop In / Stillen Grounding Kit
Borla Headers/Dual Cat-Back Exhaust
Nismo Front Bumper/Side Skirts
Impul Rear Bumper/Spoiler
AirSplat.com for AirSoft Guns!
Old Jan 21, 2004 | 03:34 PM
karlhungus's Avatar
Re: Plastic Plenum
That Carlos crossfire plenum should solve the uneven air charge distribution problem. From the looks of it, it replaces the entire intake assy. to the heads. In effect, a tunnel ram. Should be good for very large high RPM gains, but probably a significant loss of torque down low. Fine for a MT car where you can launch, but shitty for a AT unless you have a high stall convertor. Great intake for drag and strip, but wouldnt do it on a daily driver around town. Go with FI at 5-6 PSI and you have a safe, reliable 70-80 HP/torque gain with stock factory certified engine parts.
Old Jan 22, 2004 | 09:36 PM
AirSplat's Avatar
Re: Plastic Plenum
That's a good point, but how much more would it cost? FI would at least cost several G's while the intake manifold that carlos showed would probably be less than 1 G! And you may loose a little low end, but I don't think it should be detrimental.
But I still think that thing looks awesome. :-)
Old Jan 29, 2004 | 08:26 PM
Shader7's Avatar
Re: Plastic Plenum
*bump*
Any update from LSDunique?
Black/Willow 03.5 6MT, Premium, Navi, Aero, SAT
350Z Nismo CAI
jeffbdye
Jun 1, 2018 03:51 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
prinny
Nov 22, 2015 11:07 PM
thechitoguy
Oct 1, 2015 05:25 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
