Exhaust Install - Difficult?
Old Jun 2, 2007 | 10:41 PM
Jining's Avatar
Im about to recieve my Invidia g200 this tuesday, and I am curious if there is anything difficult about the install? What tools are required? Thanks a lot for any info.
Old Jun 2, 2007 | 10:57 PM
ttrank's Avatar
Grocery getter
It's not that hard as long as you can get your car up enough with jack stands. As long as you don't mind spending a couple hours under there, go for it. Otherwise a shop should do it for ~$100-150.
Old Jun 3, 2007 | 02:10 AM
Jining's Avatar
Do I just need basic tools? Socket set etc?
Old Jun 3, 2007 | 05:26 PM
mike281's Avatar
Mike Team350GZ
as long as the bolts come out good and aren't rusted or anything then ya that's all you'll need and it should go smoothly. But if your bolts are a mess and stuck in there try some WD40 or something like that. Otherwise it could turn into a headache. I did mine myself with no problems.
Old Jun 3, 2007 | 07:20 PM
c.breeze_gt's Avatar
Lisa Fleming=HOT!!!
is the exhaust y or x pipe?
Old Jun 3, 2007 | 07:30 PM
g35cas's Avatar
You might need to clear some space for the invidia exhaust to move without banging the underside. I had to put a small indentation under the passenger side so it wouldn't touch. You might not have to, but be aware of clearance issues with this exhaust.
Old Jun 3, 2007 | 09:12 PM
spudly's Avatar
Always remember PB Blaster is your friend
Old Jun 4, 2007 | 12:24 AM
gary c's Avatar
I'm on my third exhaust.........
Regardless of which system you buy there's always issues. I'm on my third
cat-back system and have always had a reliable muffler shop install them
for me.......if you can find one. I wasn't too happy with the last install
because the dude wasn't carefull enough and not very bright. My last system
and the one I using today was the easiest and it took this guy three attempts
to get it 100%. It's worth $100 to get it installed and have it done right......
with no leaks!
Old Jun 4, 2007 | 11:51 AM
StreetChase's Avatar
I installed my dads exhaust in an hour. He has HKS. As long as the bolts arnt rusted you should be fine. If i remember correctly (this was some months ago) you only need a 14mm socket. It might be a 17. One of the two lol. But anyway , good luck
Old Jun 4, 2007 | 01:32 PM
Triple8Sol's Avatar
Nah...easy. I've done quite a few exhaust mods in my time. Floor jack, jackstand, and hand tools are sufficient.
Old Jun 6, 2007 | 05:21 PM
Jining's Avatar
sweeeet... its goin on today. Tried last night but my 14mm socket isnt deep enough... homedepot to the rescue!
Old Jun 6, 2007 | 05:38 PM
MixturePinoy's Avatar
Homedepot?? go to sears yo
Old Jun 6, 2007 | 07:15 PM
Jining's Avatar
damn good idea... i just got back from HD they didnt even have the right thing..
11bEMT
May 27, 2022 03:13 PM
usingthejohn
Media Share G35 Sedan V35
Sep 17, 2015 11:37 AM
Ray Feta
Aug 13, 2015 11:40 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
