5/16" ISO Thermal Plenum Spacer vs. 5/16" Basic Plenum Spacer
Old Jun 26, 2007 | 02:54 PM
cboy's Avatar
I've searched and I still don't know what is the difference between the 5/16" ISO Thermal Plenum Spacer vs. 5/16" Basic Plenum Spacer. I know both adds 11hp to 13hp and the engine cover easily fits and never needs to be cut as per the Motordyne website. The ISO Thermal includes the Iso Thermal components, Aramid gasket and CCV. What do they do?
Can anyone help and explain?
Old Jun 26, 2007 | 02:56 PM
izmir41500's Avatar
G35driver Addict
coolant control valve shuts off coolant flow somewhere. i haven't figured it out yet since i still haven't installed mine. iirc the gaskets are adhered to the spacer.
Old Jun 26, 2007 | 03:18 PM
cato's Avatar
SouthernComfort Moderator
The Iso-thermal spacer package includes a gasket to place between the lower plenum and the intake manifold. This gasket inhibits heat transfer from the lower manifold to the upper plenum. The Iso-thermal kit also includes the coolant control valve. Earlier plenum spacers were sold before Tony developed the Iso-thermal kit. I bought the 5/8 inch spacer in a GB. Then Tony offered the Iso-thermal upgrade. Today his kits come with the iso-thermal package.
Infiniti decided to route the radiator coolant through the plenum to keep the throttle body from freezing in cold weather. The coolant control valve allows you to shut it off. I live in Texas and don't need my TB any warmer than it already is! The gasket helps prevent heat soaking of the plenum. The package is designed to allow the VQ to run cooler.
Old Jun 27, 2007 | 03:09 PM
cboy's Avatar
cato, thanks for the really helpful information.
I have two questions.
How hard is it to turn on and off the coolant control valve? And, since I live in Canada which one should I get the Iso-Thermal or Basic?
Old Jun 27, 2007 | 03:38 PM
mike281's Avatar
Mike Team350GZ
If you live in canada I would get the copper iso-thermal so you don't have to worry about turning the coolant valve on and off
Old Jun 27, 2007 | 04:36 PM
EricIsKlumzyee's Avatar
It is as hard as poping your hood and reaching under the intake tube and turning a ***..
about as complicated as starting the car
You'll like the mod
- Eric
Old Jun 28, 2007 | 07:52 AM
cato's Avatar
Like they said.
In Canada, the only reasonable choice would be the copper option. You will never need to think about it.
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
the93owner
Oct 4, 2015 09:40 AM
thechitoguy
Oct 1, 2015 05:25 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
