Spacer question
Old Jul 9, 2007 | 09:21 PM
BuckeyeG's Avatar
Spacer question
I just installed my 5/16 iso copper spacer. Ive got a pop and Z tube. Ive noticed after the install that when I hit the gas about 1/8 or less that I get a high pitch sound kinda like a turbo. I think its my pop charger sucking more air into the plenum with the spacer. Ive just never heard it before while I wa driving with the windows down. I cant hear it with the windows up and it only happens when I hit the gas. I just want to make sure I didnt F something up.
Thanks
Old Jul 9, 2007 | 10:47 PM
ttrank's Avatar
Grocery getter
Sounds like the intake whine to me. If there was a pressure drop or problem you would get a SES light.
Old Jul 9, 2007 | 11:11 PM
jmonsale's Avatar
Thanks
Yeah, mine does the same. I remember reading that the popcharger filter itself is designed like a venturi inside. For those of you who are familiar with a venturi it uses the bernoulli principle where gas that is forced through it increases in flow. The flow increase depends on the air entrainment ratio (supplied by the air entrainment port) of the venturi. That increase in flow is probably what you hear when you punch the gas. From seaching I know that JWT and I believe stillen filters uses this concept. I'm not sure about others.
Old Jul 9, 2007 | 11:29 PM
StarChamp's Avatar
I get the same whistling/whine sound with my K&N filter, Nismo CAI, and Skunk2 spacer. I've been running it for about 18 months now, and no problems whatsoever.
Old Jul 9, 2007 | 11:34 PM
chinaman_87's Avatar
Same sound and no problems here.
Old Aug 25, 2008 | 06:46 PM
BIGD28's Avatar
stillen intake makes the same noise
Old Aug 26, 2008 | 12:50 PM
Mmagic76's Avatar
Same sound, stock intake with z-tube and 5/16 spacer.
Old Aug 26, 2008 | 06:55 PM
geesteezd's Avatar
same sound w/ stillen z tube, pop charger, 1/2" MD
Old Sep 5, 2008 | 07:59 AM
infg35x's Avatar
same sound with stillen intake, z tube and spacer. It just started happening one day and I was thought it was the belts.....I was like no way could the belts go bad over night. It's definitely the intake and you can only hear it when you on the gas a little bit.
Old Dec 14, 2009 | 08:24 PM
gsoto999's Avatar
Just got mine installed today at Infiniti of Riverside. I got the Motordyne 5/16 iso copper spacer and Stillen Z tube intake combo.. i got the same suction/whistling sound and i love it! LOL sounds mean!
Old Dec 15, 2009 | 01:00 AM
myC17isfaster's Avatar
c'mon ttrank, you're an aersospace engineer and you let jmonsale beat you to the punch with the technical reason?
but ya all you're hearing is the air flow increase in velocity as it moves through the nozzle-shaped pop charger. its a nice touch.
Old Dec 15, 2009 | 10:57 AM
bluemax189's Avatar
same here, i got the ztube, jwt pop, md 5/16 and nonrevup lower. i get the whistling sound at lower speeds, although its gona away a little bit recently. Probably due to the fact my filter needs good cleaning.
Old Dec 15, 2009 | 11:38 AM
NFSP G35's Avatar
? = 2B || !2B
I get that sound on mine and it's just a cheap eBay CAI for the Z
Old Dec 15, 2009 | 12:12 PM
geew1z's Avatar
not to hijack.. but i noticed that the skunk2 plenum spacer comes with hardware to bypass heating the TB. The motordyne one comes with that copper thingy to specifically heat the TB (i live in NE ohio and need that)..
What is usually heated that these spacers are supposed to bypass? and although I understand that the TB needs to be heated in the winter, why does the skunk2 specifically bypass that?
Old Dec 15, 2009 | 02:01 PM
NjMatteSedan's Avatar
same whining sound with ztube and pepboys air filter
