Compression Test
Old Jul 12, 2007 | 01:30 PM
HONZ-S13's Avatar
Compression Test
Hey Guys,
I am looking at buying a LR G coupe this week and want to perform a compression test before purchasing it.
Does anyone know what the factory compression numbers are suppose to be?
Cheers
Old Jul 12, 2007 | 08:33 PM
imaxorz's Avatar
Huh?
Old Jul 13, 2007 | 09:31 AM
HONZ-S13's Avatar
Does no one know?
Someone must have done one on a G they bought used...
Old Jul 13, 2007 | 09:32 AM
HONZ-S13's Avatar
Originally Posted by imaxorz
Huh?
Sorry if this is too heavy of a topic for ya.
Old Jul 13, 2007 | 09:58 AM
05BLACK6MT's Avatar
If you don't know the # just make sure the # are close to each other on all 6 then you will be fine.
Old Jul 13, 2007 | 10:06 AM
da mayor's Avatar
why would you do a compression test on a new car? besides its all in the break in period.... if you don't break it in you'll definitely be asking for trouble
Old Jul 13, 2007 | 10:07 AM
ISMSOLUTIONS's Avatar
Factory new - 140's to 160's...a few years old with miles, should be in the 130's I would think.
Rick
Old Jul 13, 2007 | 08:08 PM
HONZ-S13's Avatar
Rick
Thanks Rick, I am looking at 03-04's with 30k - 50k miles. I glad someone knows the answer to this question!
Cheers
Old Jul 13, 2007 | 08:51 PM
rlwjr1's Avatar
Here ya' go, this is from Nissan/Infiniti:
Compression pressure kPa (kg/cm2, psi)/300 rpm
Standard 1,275 (13.0, 185)
Minimum 981 (10.0, 142)
Differential limit between cylinders 98 (1.0, 14)
Here's a link showing how to do it:
http://alldatapro.com/alldata/PRO~V6...00695/58800700
Hope this helps. And who cares what others are saying about it being a new car. At least you have a baseline and peace of mind. If you can do it also do a leak down test. This requires specialized equipment and an air compressor but it will give you a better idea how the engine and valves are sealing....
Old Jul 13, 2007 | 10:20 PM
Sorry - but it does matter if it is new or not. The ratings posted by 'others' are for a new engine. An extremely used or abused engine, will have lower, potentially much lower, numbers. It's important, because is you get a car with 30,000 miles on it, and the pressure is 30% lower than new, then the car has been abused or there are other issues. On the flip side, you get a car with 60,000 miles on it with pressure ratings of a new engine, then you really have a well taken care of vehicle with a string engine.
These are the things you want to know when buying a used car.
Rick
Old Jul 15, 2007 | 02:36 PM
HONZ-S13's Avatar
You never know how a car has been driven regardless if its 50 miles or for 50,000 miles.
Thanks for all the help guys. I will post some results when I find the right car.
Cheers.
Old Jul 15, 2007 | 03:03 PM
Cheers.
Not necessarily true - it depends on what you look at, and how good you look.
Rick
Old Jul 15, 2007 | 03:22 PM
GreenGoblin's Avatar
The goblin resurrection
^ i agree
Old Jul 16, 2007 | 01:52 PM
Jeff92se's Avatar
Red Card Crew
Rick
Um well, just looking at the engine won't reveal much. Unless it's leaking oil all over the place. A hard driven car can be cleaned up pretty good.
A compression test is a good thing to get on any car (newish or not)
A cylinder leak down test would be anther one.
If you are getting this done at a shop, have them run an OBDII for codes and contact the dealer to have the service records brought up for you.
Old Jul 16, 2007 | 03:31 PM
Exactly what I meant - it depends on what you look at and how.
Rick
KruZZe
Feb 27, 2023 05:04 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
prinny
Nov 22, 2015 11:07 PM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
