Tell me if I should seal this on my CF Z-Tube
Old Jul 19, 2007 | 07:48 PM
digitalhifinet's Avatar
I just bought a used Stillen Hi-Flow and a carbon fiber Z-Tube and I am thrilled. However part of it does not seal off (I believe it is the exhaust connection, see pics). I could get a new grommet, or maybe find some high heat glue to get the grommet to seal on the curved tube surface. Does it need to be completely sealed off?
Thanks guys...
Old Jul 19, 2007 | 08:41 PM
GreenGoblin's Avatar
The goblin resurrection
it is a vac line it sould be fine
Old Jul 19, 2007 | 09:13 PM
My main concern is that with the grommet passing air my intake would be taking in air not through the air filter.
Old Jul 19, 2007 | 09:29 PM
install it and run you fingure around it to see if there is any suction, if there is then use some silcone or something to seal it up but im sure you wont need to
Old Jul 20, 2007 | 09:46 AM
dovla's Avatar
There, you should connect the crankcase breather hose (black ~1” tube) that on the other side is connected to the valve cover in the rear of the engine on the driver side.
Unless you have put a small breather filter to that hose or oil catch can (which is unnecessary IMO because there is no oil to catch on this side), in which case you should close “the grommet on the curved tube” by putting the 5/8” nipple ($0.25 at any auto parts store).
Dallsinghjr1
Sep 17, 2023 11:25 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
prinny
Nov 22, 2015 11:07 PM
