help? Just installed the injen cold air intake but
Old Jan 22, 2004 | 03:52 PM
b8b88's Avatar
my "service engin soon" light is on , I dont know why? Does anyone has the same problem with me. I checked the connection and everything, it all connected very well, any clue???
Old Jan 22, 2004 | 04:37 PM
Shader7's Avatar
Re: help? Just installed the injen cold air intake but
Unknown, mine never did that after install. Maybe reset your ECU?
Black/Willow 03.5 6MT, Premium, Navi, Aero, SAT
350Z Nismo CAI
Old Jan 22, 2004 | 05:35 PM
gould2000's Avatar
if you left the battery plugged in while you did the install, and unplugged the MAF while the battery was plugged in, I believe this will trip the light.
Old Jan 22, 2004 | 05:39 PM
XCELR8's Avatar
I have the Injen waiting to be installed once the weather gets nicer. How many people have had the "check engine light" or other repercussions occur after installation? I was hoping for a bolt on and drive away. If its going to be a big problem I'll send it back.
2003 BLK/BLK 6-spd Injen clear corners
Old Jan 22, 2004 | 06:39 PM
SkyLine350GTs's Avatar
It was a direct bolt on, on my sedan. I have had no problems at all. I love the injen cai, its my favorite mod so far, and it sounds bad-A$$. To fix your problem, just do the ecu reset and that should take care of it.
High Point NC
04 G35 6MT Sedan, Diamond Graphite on Black.
Arrived on 10/20/03
Mods include.
20% tint
INJEN CAI, black
clear bra
clear corners
Rip 2002 Altima 2.5s blk/grey 5/30/02-10/7/03
Old Jan 23, 2004 | 12:43 AM
GurgenPB's Avatar
I can state with pretty good (95%) certaintly that you dd not disconnect the battery before unplugging the MAF, or you accidentally started the car with the MAF unplugged (less likely).
Gurgen.
Old Jan 23, 2004 | 01:58 AM
NicNoobie's Avatar
I believe I've read other posts on the topic, which is why I disconnected the negative terminal when I installed my CAI. Thankfully, I haven't had any problems w/ the service light at all. Not sure how to resolve your problem tho, sorry. Good luck.
- NICNoobie
2003.0 AT Brilliant Silver Sedan
Premium Package\Graphite Leather\Signaling Clear Corners\AEM Intake (w/ Bypass Valve)
"Why are you my English not being understanding?"
Old Jan 23, 2004 | 11:13 AM
Shader7's Avatar
I didn't disco the battery when I did mine; no problem with the dummy lights at all.
350Z Nismo CAI
Old Jan 23, 2004 | 11:14 AM
b0hr's Avatar
I set mine off after puttin the MAF on backwards. after a fix and an easy ECU reset it was fine. Search on here how to do it. it takes a good 30 seconds
Old Jan 23, 2004 | 11:27 AM
DaveO's Avatar
I've unplugged my MAF Sensor with the battery connected at least a 10 times (twice yesterday) and never triggered the "service engine soon" display. I did forget to reconnect it once and immediately brought in display when I started the engine.
DaveO
2003 G35 Sedan - DP / Willow / AT / Premium / Sport
350Z Engine Cover, T-Stat & Air Duct / Stillen CAI
GG 7-Wire H-G Kit / TS ECU / E-Fans
Street Edge TC / B&M Cooler / Stillen Exhaust
champppy
Mar 31, 2020 12:25 PM
Greg Huston
Sep 25, 2016 11:36 PM
MR M37s
Oct 30, 2015 08:32 AM
underworld
Aug 6, 2015 01:36 PM
paniaguag35
Jul 29, 2015 12:05 PM
