cleaning your filter on a stillen intake?
Old Jul 29, 2007 | 01:43 AM
cchaorule's Avatar
i had the stillen intake on my car for 15k miles now.. do anyone take it out and clean the filter??
Old Jul 29, 2007 | 10:14 AM
g35rcr's Avatar
why wouldnt you take it out to clean...
Old Jul 29, 2007 | 10:21 AM
gary c's Avatar
Your Late........!
Go to any autoparts store and get the K&N kit which contains both the
cleaner and the oil. At 15K miles you're late cleaning the filter! They should
be cleaned every 5K or no less than 10K miles. When you get into cleaning
the filter make sure you read carefully the instructions and follow them.
Old Jul 29, 2007 | 11:47 AM
TURBOTOM's Avatar
a.k.a kleicoupe
Yea the K&N filter cleaner works great, i just did mine. You can get it at almost any auto parts store.
Old Jul 30, 2007 | 12:55 AM
Andy2434's Avatar
I clean the Stillen filter every 5k miles. Get an extra filter. That makes the whole process much simpler.
Old Jul 31, 2007 | 06:00 PM
TakaBlackG35's Avatar
Would you still be able to use the K&N cleaner kit for a Blitz SUS Power filter? Supposedly it's stainless steel mesh so I dunno if it's the same cleaning process as a regular K&N filter. Maybe just use the cleaner and not the oil?
Old Aug 3, 2007 | 06:19 AM
jimmykce1's Avatar
I know some people replace their Stillen air filter with a AEM dry filter.
Old Oct 10, 2007 | 02:14 AM
BayAreaRefuGz's Avatar
i fly low
where can i buy just the cone.. i swapped back to stock and i have to reset the ECU again after i put my stillen back on..
Old Oct 10, 2007 | 09:07 AM
r0csfinest's Avatar
wat if u havent cleaned urs in a looooongtime?
Old Oct 10, 2007 | 08:32 PM
fortified's Avatar
I don't know where this cleaning every 5K or even 10K comes from. According to K&N (if you believe the hype and you must if use their filter) every 30K to 50K is enough!
http://www.knfilters.com/filtercharger.htm
In fact, K&N claims filtering ability is supposed to improve as some dirt builds up. Less than 10K sounds like a lot work for no gain.
But if you think K&N passes too much dirt (and there are tests to show it does pass more than other types) cleaning it more often does nothing to help that.
Not saying NOT to use it, use your judgment, but I don't see how cleaning it so often is helping anything at all except keep it more pretty on the outside.
If you believe this is the best kind of filter, then you might check out one that is supposedly better made and is thicker to capture more dirt.
Can't think of the name, looks like a K&N but thicker. It's been discussed here before.
Old Oct 10, 2007 | 09:16 PM
obender66's Avatar
I agree. I clean my annually(comest about 15K miles), because it starts to look dirty and ugly, but I don't feel any difference after cleaning. What's the point to have no use of car for a day and waste your time disassembling air box?
Old Oct 10, 2007 | 09:40 PM
r0csfinest's Avatar
that's good to kno... Guess i need to clean mine soon tho. Thanks
Old Oct 11, 2007 | 12:30 AM
PSD G35's Avatar
I have had mine on my car for about a year now. Previously I clean mine out annually, which is approximately every 9K miles. I get tons of dirt, each time.
Old Nov 7, 2007 | 01:22 PM
mpspeer's Avatar
Patrick
Can you use the K&N filter cleaner with a pop charger? or is it recommended to use the JWT stuff?
Old Nov 7, 2007 | 01:50 PM
Jeff92se's Avatar
Red Card Crew
No. I doubt that filter gets dirty anyway. That thing lets the world and it's mother past the filter. Worst filtering unit I've seen. You might was well not even use a filter.
