Urgent Part 2!!!
Old Sep 2, 2007 | 06:55 PM
adusg35's Avatar
Urgent Part 2!!!
ok so, me and my friend install a 5/8 skunk2 plenum spacer onto my 04 g35 coupe (5spd). we installed it and started the car. we started it and realized the idle was really low. then we took it for a drive and all hell seemed to break loose. its not accelerating worth crap, it tends to jump on and off, it dies at stop.
SOMEONE HELP!!! where could we have gone wrong on the install. we did everything (or thought we did everything) correctly. if you guys could leave suggestions on wat to check or wat to do it would be REALLY helpful
Old Sep 2, 2007 | 07:11 PM
BracketRacerSteve's Avatar
Make sure you put gaskets top and bottom.
Reset the ECU.
Old Sep 2, 2007 | 07:20 PM
adusg35's Avatar
theres sealant at the top and a gasket at the bottom.
the problem was still continuing after i reset the ecu unless theres a learning curve for it
Old Sep 2, 2007 | 07:35 PM
brianmfournier's Avatar
Did you disconnect any hoses from the upper or lower plenum?
Old Sep 2, 2007 | 07:42 PM
adusg35's Avatar
i disconnected a hose from the top left, one from the intake, and the intake itself. i didnt take off the throttle body and coolant cuz it seemed pointless. i plugged all the hoses back in. could it be that the bolts arent tight enough?
could all this be caused by a missing bolt??
Old Sep 2, 2007 | 07:48 PM
ISMSOLUTIONS's Avatar
Sounds like vacuum leak to me...
Old Sep 2, 2007 | 07:56 PM
OCG35's Avatar
sealant?... I've only used Motodyne but it's been on & off... never used sealant...
Old Sep 2, 2007 | 08:00 PM
adusg35's Avatar
ok problem solved guys thanks alot!
it turned out that we didnt have the top part of the intake on. it looked like it was on but it wasnt. yes i know small and stupid problem but damn. im glad its solved!
Speck102
Mar 26, 2018 11:48 AM
Greg Huston
Sep 25, 2016 11:36 PM
DarkLyter
Jul 28, 2015 04:57 PM
