Connecting G35 PCV hose to 350Z intake tube
Old Feb 18, 2004 | 01:39 AM
TooFastSGG35's Avatar
I don't think that I can find what I am looking for in an answer nor do I think that I have seen it in the past so I will ask. I know that many of you hvae installed the 350Z intake tube to your G35 and I was wondering since the stock setup has the PCV hose connected on top of the tube and the 350Z connects on the bottom I am sure that you have run into the problem of the PCV hose crimping up on you. I was wondering other than cutting the hose if anyone has found another solution. I would rather not cut it if I don't have to. Thanks!
Old Feb 18, 2004 | 07:54 AM
GLuvin's Avatar
Re: Connecting G35 PCV hose to 350Z intake tube
I did not have to cut it, you can work that slack back towards the firewall.
03 - Black - Premium - Wood - Aero w/ Spoiler - Z Tube - Grounded - Stillen CAI
Old Feb 18, 2004 | 08:12 AM
cato's Avatar
SouthernComfort Moderator
Yea, no reason to cut it. Just connect it and work it down under.
2003 Twilight Blue 5AT Sedan, sunroof,
Graphite Leather, splashguards,
12 wire Hyper-grounding kit,
350Z intake duct, Stillen Hi-Flow Airbox
Underbody rear diffusers, Drilled aluminum pedals
Old Feb 18, 2004 | 09:53 AM
z_with_back_seat's Avatar
No need to cut it. The only other alternative is to get the hose from your Nissan parts supplier for the Z. I actually looked at buying one last week. Retail is around $17. Unless you are showing your car, I do not see any reason to do that. The one that is on there will work out for you just fine.
G35C - 6MT, DG/G, Aero, BSM, Flaps, Stillen Intake, Z tube, Crawford v5, 6 Wire Grounding Kit, Clear Corners, 2nd Battery (Brake) Cover, Sirius, Momo F16 Evo Shifter, 30% 3M Tint & more to go
Old Feb 18, 2004 | 04:42 PM
RavenR's Avatar
Oh crap, is this hose important? Cuz when i installed my Z Tube, I didnt connect the hose to anything because i didnt see that in the DIY...maybe I just missed it..
Ivory Pearl Coupe/5AT/Aeros/Premium/Nav/Type-N Front Bumper/Z-Tube/V1
Old Feb 18, 2004 | 05:09 PM
RamboRami's Avatar
G35driver.com Moderator
are you sure Raven? thats the MAF sensor i believe, without it the car wont even run in gear.....
maybe you just forgot that you connected it, because its now hidden underneath, its a simple plug-in that takes 1 second to do..... i think you just forgot that you did it. But check just to make sure. Let us know. Thanks
G35c-6MT-DG/Willow/HyperGround/BorlaExhaust/350Z-intake
Old Feb 18, 2004 | 05:28 PM
RavenR's Avatar
Im about 99% sure that i did not connect it..the reason why i know this is because when i was installing...i remember saying...Where the F does this hose go? I remember looking on the Z tube and not finding a hole for the hose to go.....i put in the Z tube like a month ago and the G runs fine...i hope im not causing any damage....
Old Feb 18, 2004 | 06:05 PM
badtz's Avatar
I would think the only danger in not connecting it, is that you may be sucking junk in the air into your engine. The PCV inlet bypasses the air filter. The hose side is going to vent noxious fumes into the atmosphere.
Old Feb 18, 2004 | 06:39 PM
khsonic03's Avatar
It also acts as crankcase ventilation. I would definately attatch it ASAP. If not, the engine could blow a valve cover gasket. (not likely unless you have FI, but still possible) Pressure builds up in the crank case, and this tube helps to relieve that pressure by sucking it into the intake. It is also a vent for emissions purposes.
'03.5 Brilliant Silver AT Sedan, Premium, Aero Kit/Package, Sport, Winter, Stillen Air Box, Z pipe, Clear Corners, Alum. Pedals, Polk Tweeters, Clifford RSX 3.5, Gram Light 57F Pro's (on the way!)
Old Feb 18, 2004 | 07:29 PM
RavenR's Avatar
Ok im connecting it as soon as i get home...thanks guys!
Old Feb 20, 2004 | 01:38 AM
yep thanks!
Old Feb 20, 2004 | 07:53 PM
tonio's Avatar
Raven, have you been getting any weird noises under your hood while driving?
Old Feb 22, 2004 | 08:13 PM
RavenR's Avatar
No none at all. My car sounded and operated perfectly fine under all conditions, but to be sure, ive connected the hose.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
lemmy999
Jul 25, 2015 12:13 PM
laksjd84
Jul 24, 2015 05:12 PM
netcbc
Engine - Intake/Fuel CDN
Jul 24, 2015 02:21 PM
HypedAndy
Southern California
Jul 21, 2015 03:46 PM
