Plenum Spacers: The Positive/Negative Factors.
Old Nov 6, 2007 | 10:12 AM
Midnightblue04's Avatar
Post Plenum Spacers: The Positive/Negative Factors.
What's going on. I was looking into getting the Plenum spacer for my G35. I just wanted to get your inputs about this before purchasing it. Im looking into getting the AAM one for $269.99. Heres the link to the spacer: AlteredMotorsports.com . Reason because I can get them to Install it since I live near MD. But does anyone have experience with this plenum?
Also, Using these aftermarket plenums, I know it helps air flow to the front cylinders etc. but doesn't it set the injectors a different and have a bad aim?
I guess my questions areicon17:
Is the AAM plenum spacer (And Intake) good?
What's the worst that can happened with these spacers?
Intake and spacer and installation for $650. Good deal?
Thanks
Sorry, this probably has been posted millions of times. My apologies again.
Old Nov 6, 2007 | 10:34 AM
93 til Infiniti's Avatar
Worse that can happen w/ a spacer...you get NO power or even a loss of. I've read all the raves and rants about the good and bad, dyno specs and personal grief, etc. I hear that the Motordyne 5/16 is the best choice.
Forget the installation....DIY! Its not rocket science to install a spacer AND and an intake...even a CAI is pretty easy.
Old Nov 6, 2007 | 12:46 PM
Triple8Sol's Avatar
Go with the Motordyne.
Old Nov 6, 2007 | 12:54 PM
jonnVQuest's Avatar
Hows the Junk2 Stack up?
Old Nov 6, 2007 | 01:06 PM
Jeff92se's Avatar
Red Card Crew
motordyne's website. THEN ask questions
Old Nov 6, 2007 | 01:45 PM
Scrooge's Avatar
I read tht there not carb legal. Thats why I didn't get one.
Old Nov 6, 2007 | 01:54 PM
redlude97's Avatar
There is absolutely no way that an officer without specific knowledge about the VQ engine would be able to notice the MREV2/spacer. Especially with the stock cover on.
Old Nov 6, 2007 | 02:34 PM
Scrooge's Avatar
I just wanted to be safe.
Old Nov 6, 2007 | 02:38 PM
I have been to the site.
But I'm just trying to get info about the AAM spacer.
Old Nov 6, 2007 | 02:50 PM
Jeff92se's Avatar
Red Card Crew
Again I have to ask why are you considering this spacer (after reviewing this dyno graph). the install of either teh spacer or plenum is pretty easy
Old Nov 6, 2007 | 02:53 PM
Don't really have the time to do it. I'd rather get it done right the first time. But, thanks for the charts.
Old Nov 7, 2007 | 04:37 PM
Derek173's Avatar
"Intake and spacer and installation for $650."
WTF!!!!!
Old Nov 7, 2007 | 04:41 PM
Skaterbasist's Avatar
Retired SuperMod
Get a Motordyne Spacer + MREV 2 and install it yourself. It's a piece of cake.
There are no "negative" effects of a spacer and/or modified lower plenum.
Old Nov 7, 2007 | 07:39 PM
g35ctuner's Avatar
i got one! does the ''angle'' make a difference vs. the md flat design? i dont think so, but just want to get some opinions.
Old Nov 7, 2007 | 07:47 PM
GsgottaG's Avatar
If AAM is charging you $400 to install they are hosing you !!! I bought an AAM spacer. I have never done work on any car before this and it took me less than a hour to install. Spend an hour and learn something. Use the $400 for an MREV2 or something....
