anyone have gasket seal issues with crawford plnm?
Old Feb 21, 2004 | 03:02 AM
AznIceRckt's Avatar
hi i'm trying to install the crawford plenum v5 in my car, and everything is fine, except i have what i belive is a small vacuum leak.
the car is making a slight hissing sound, and it gets louder when you turn the car off. the check engine light is also on. i'm probably just going to double gasket it... already have extra gaskets... anyone have similar problems? or have any suggestions? thanks.
-phil
*** 2003 G35s 5a/t / Pearl White ***
Old Feb 21, 2004 | 03:12 AM
pestilence's Avatar
Re: anyone have gasket seal issues with crawford plnm?
Hi AznIce... I have the plenum on my sedan and have no leaking issues... I konw when installing the plenum you have to seal the two screw holes inside the air intake chamber... did you do that?
Old Feb 21, 2004 | 08:27 AM
booger's Avatar
You may want to check and see if you got part of the rubber thing around the oil fill squeezed between the upper and lower plenum
Couldnt afford it when young...gonna play when Im old
murphd3rf
27
Oct 16, 2023 02:15 AM
jbmw002
Drivetrain
Aug 27, 2015 03:01 PM
Gookiecrunch
Aug 19, 2015 12:00 PM
eunosz
Engine - Complete Motors
Aug 11, 2015 08:35 PM
newg37
Jul 26, 2015 09:32 AM
