louder stock exhaust?
Old Dec 2, 2007 | 02:06 PM
ChamCham's Avatar
is there anyway u can make the stock exhaust louder?
Old Dec 2, 2007 | 02:07 PM
patman530's Avatar
replace stock cats with high flow cats or test pipes
Old Dec 2, 2007 | 02:10 PM
ChamCham's Avatar
will it change the sound of the stock exhaust tho?
Old Dec 2, 2007 | 02:18 PM
patman530's Avatar
stock with strup test pipes:
stock with FI high flow cats:
Old Dec 3, 2007 | 09:38 AM
Beebo's Avatar
+1 Fast Intentions High Flow Cats... they will make the exhaust deeper and louder... test pipes rasp to much sounds nasty
Old Dec 3, 2007 | 09:41 AM
StreetChase's Avatar
I put some Fast Intentions High Flow Cats on a while back. It makes the exhaust a little louder and a little deeper. I also have a Z tube. You could throw headers on too if you would like.
Old Dec 3, 2007 | 09:47 AM
MIA BlazinVQ's Avatar
brb getting cut
yo did you get any check engine lights or anything weird at all? im thinking im going to go ahead and buy them after seeing the clip above
Old Dec 3, 2007 | 10:26 AM
Calvin's Avatar
Overglorified Altima
you should not throw any codes with high flow cats.
Old Dec 3, 2007 | 12:34 PM
partyman66's Avatar
Some people have removed the resonater on their exhaust and welded in a solid piece of pipe in its place to make the car slightly louder with an otherwise stock exhaust.
Those who have done it seemed to have been happy with the results. Personally, I'll probably be going with a full cat-back system when spring rolls around.
Old Dec 3, 2007 | 01:19 PM
Calvin's Avatar
replacing the resonator in the midpipe will cause rasp. i speak from experience.
hell, even people that have replaced it with a smaller resonator were not all happy. that caused rasp sometimes, too.
Old Dec 3, 2007 | 02:57 PM
2EFNFAST's Avatar
headers and high flow cats - similar stock note, hella lot louder.
oh yes, sounds good to remove the resonator!! (sic)
http://videos.streetfire.net/video/40abdc1a-a5a6-47d3-a6dc-42119b56414b.htm
Old Dec 3, 2007 | 03:28 PM
jigahus's Avatar
There is a sale on FI HFC's and cats in the vendor market place.
Old Dec 3, 2007 | 03:33 PM
OnE BaD G35's Avatar
Yeah my cousin also had his resonator removed on his 06' g35c and it sounds horrible. Worst way to go.
Old Feb 15, 2008 | 12:54 PM
DRA-G35-ON's Avatar
http://youtube.com/watch?v=cX1HuUMTick
http://youtube.com/watch?v=oZwi5s78n2g
I couldn't decide between Crawford or FI HFC's, but after hearing that video clip, I think I'm gonna go FI...
Thanks Patman!
Old Feb 15, 2008 | 01:44 PM
tommyz9's Avatar
Will I still pass smog check if I add Fast Intentions High Flow Cats? It is illegal? thanks.
