Z Tube whistle/chirp
Old Mar 3, 2004 | 06:23 PM
andyranck's Avatar
I doubled checked my install tonight, and the tube is extended all the way on the airbox and manifold ends. Whenever I step hard on the accelerator, I hear a quick chirp, regardless of rpm. It's most noticeable if I'm trolling along in 3rd at like 15-20mph, then step hard on the gas. Then when I cross 3200rpms, it chirps again. It's faint, but high pitched enough for me to notice if the moonroof or windows are open. Does this whether the engine is cold or warm, clutch in or out in any gear. Is this normal?
I have not done an ecu reset, as I assumed it wasn't necessary for such a basic mod.
Drew
2003 G35 Sedan 6MT / Black / Graphite / Prem / Aero
Old Mar 4, 2004 | 10:10 AM
RamboRami's Avatar
G35driver.com Moderator
Re: Z Tube whistle/chirp
chirp? are there birds in your engine bay? or are you chirping the tires?
hmm, never heard anyone describe an engine sound as a chirp... sounds like something odd, try to put back your stock intake tube and see if it happens. Inspect your Z-tube, make sure there are no defects in it. Then try your install again.
If all else fails, see the dealer
G35c-6MT-DG/Willow/HyperGround/BorlaExhaust/350Z-intake
Old Mar 4, 2004 | 12:08 PM
khsonic03's Avatar
I would call it a chirp. That is normal. It whistles, and if you step on the gas quickly it does give a short whistle/chirp.
'03.5 Silver AT Sedan, Premium, Aero Kit/Package, Sport, Winter, Stillen Air Box, Z pipe, Polk Tweeters, Clifford RSX 3.5, Gram Light 57F Pro's (on the way), Hotchkis sways
Old Mar 4, 2004 | 01:04 PM
tonio's Avatar
mine does the same thing, Jason at performancenissanparts.com assured me that this is normal, it is because the air is flowing through the z-tube a lot faster than the stock set up.
Old Mar 4, 2004 | 07:43 PM
GLuvin's Avatar
It is very common, mine did it until I added the Stillen air box. There are few other threads about it. Nothing wrong with your install. best description is have heard is your car can now whistle at the ladies.
03 - Black - Premium - Wood - Aero w/ Spoiler - Z Tube - Grounded - Stillen CAI
Picture Share
Feb 4, 2018 12:41 PM
Video Share
Jan 31, 2017 04:00 PM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
prinny
Nov 22, 2015 11:07 PM
