Intake + Header + Exaust, worth it?
Old Jan 2, 2008 | 04:17 PM
Xattica's Avatar
Hi,
I have a Sedan 2003, 5AT, Virgin G35.
I was wondering if adding Intake + Header + Exaust worth it. I know that TT could be a great addition, but how much rwhp I can get without force induction upgrade?
Regards,
Xat
Old Jan 2, 2008 | 04:26 PM
elayman's Avatar
i'd give you a rough estimate of a max of 15hp? with a plenum and spacer you could pull off maybe 30+? someone jump in and correct me, but it's nothing compared to F/I gains
Old Jan 2, 2008 | 04:27 PM
elayman's Avatar
and im actually not sure if the plenum and spacer fits on the sedan, so someone jump in =]]
Old Jan 2, 2008 | 04:29 PM
Xattica's Avatar
Thanks.
Then by now, Cost vs hp gain is no effective.
Texasscout's Avatar
Yeah, it does and that's about what you should expect. I don't see the headers doing much without a low restriction exhaust of somekind.
Skaterbasist's Avatar
Retired SuperMod
"Worth it" all depends on you. Even if its not worth it, I'd still do it, because its an addiction & passion for me.
Full NA (Intake, Plenum Spacer, MREV2, Exhaust, Cats/TP, Headers, & tune) will probably yield 35 peak rwhp / 30 rwtq at max. (The change in the overall powercurve, especially mid-range, might be more attractive than the peak power itself).
You could always get yourself a Vortech complete kit and use it right out of the box installed for maybe ~$2000 more than you would spend going full NA.
Old Jan 2, 2008 | 04:31 PM
Texasscout's Avatar
Originally Posted by Xattica
Thanks.
Very true, these motors are tweeked quite a bit as it it. It's not like a Chevy small block that you can bolt an intake, Carb, Headers and low restriction exhaust and get an additional 75HP.
Old Jan 2, 2008 | 04:35 PM
Xattica's Avatar
Then, what will be the best mix? What brands?
Old Jan 3, 2008 | 02:57 AM
Beebo's Avatar
MD 5/16 Spacer, JWT pop charger/z-tube or Stillen/z-tube, coupe mid pipe, HKS rear exhaust section
be sure to reset your ECU after installing the mods
Old Jan 3, 2008 | 01:52 PM
TheTick's Avatar
15whp should knock off about 0.2 seconds off your 1/4 time and about 0.1 seconds off your 0-60 time. You'll also get a nice aggressive sound, so I would say for most people on these forums would say that it is worth it.
Mine is more of a family car, so I prefer the quiet sound. So for me it's not worth spending upwards of 2 grand for bolt on mods that give very little gains and lots more noise. If I was single though...I would do intake, spacer, and exhaust at least.
Old Jan 3, 2008 | 10:36 PM
nyqueenz's Avatar
if go go NA i would build the engine.. to high compression.. bore out to maybe a 3.8L.. if u really wanna see high gains
Old Jan 3, 2008 | 11:00 PM
Texasscout's Avatar
High compression? They are already 10.5:1 now! Now there is a stroker kit that gives you 4.1L, that way you don't have to do a lot of machine work.
BC0229 - Brian Crower VQ35 Stroker Kit
The BC stroker kit for the Nissan VQ35DE engine platform incorporates a 88mm stroke, steel billet crank, BC 4340 Pro Series Billet rods rated to 1200+ horsepower. Depending on bore size that you decide, the BC kit will take you up to a 4.15L with 100mm bore. As usual, each BC kit features custom CP aluminum forged pistons, 9310 alloy wrist pins, ring pack and buttons. Available in any desired bore and compression ratio for use in turbo or normally aspirated.
BC 4340 billet steel crankshaft (88mm or 86.4mm stroke).
BC 4340 Pro Series steel billet connecting rods w/ARP 220,000 psi fasteners.
CP aluminum forged pistons (any bore size, any compression ratio).
9310 nickel carbon steel alloy wrist pins.
Ductile iron plasma top rings, tapered second ring, low tension oil rings.
Typically includes aluminum buttons/rail supports (not locks).
Requires balancing. 88mm stroke requires block clearancing. Please specify bore and compression ratio desired when ordering.
Price: $ 5,200.00 / Each
Or Cosworth has a really nice short block and heads...
Nissan VQ35DE (350Z-G35) High Performance Short Block 3.5L
The Cosworth VQ35DE high performance short block is the perfect foundation for your high performance application. Each High Performance Short Block is hand assembled by one of Cosworth’s skilled engine builders to exact specifications utilizing all new components and is available in either high compression 11:1 or low compression 8.8:1 for turbo or supercharged applications. To ensure smooth operation throughout the entire RPM range, each rotating assembly is carefully balanced, an essential requirement for high performance VQ35s. Additionally, comprehensive build sheet listing all critical dimensions is included. Use with our CNC ported Big Valve Cylinder Heads for maximum reliable performance.
Each short block features:
• Cosworth Forged Pistons (95.5mm)
• Cosworth Forged H Beam Connecting Rods
• New Nissan Forged Crankshaft (81.4mm)
• Cosworth High performance Rod and Main Bearings
• Cosworth High Performance Main Bearing studs
• New Nissan VQ35 Alloy Block
• Complete balancing of rotating assembly
• Cosworth serial number
Part #20000067 Nissan VQ35 Short Block (3.5L) Lo comp 8.8:1
Part #CI8019 Nissan VQ35 Short Block (3.5L) Hi comp 11:1
Cosworth Nissan VQ35 CNC Ported Big Valve Cylinder Heads.
Cosworth VQ35 CNC ported cylinder heads feature dyno tested and flow bench proven ports, engineered for maximum real world power. Each new cylinder head is ported on a 5 axis machine to ensure consistency and perfect port shape every time. Additionally, larger intake (+1mm) and exhaust valves (+1mm) are utilized to help increase flow. Cosworth CNC ported Big Valve cylinder heads come complete with a performance valve job, hi rev (max 10,500rpm) valve springs with titanium retainers and are ready to install. Perfect for big turbo applications or strong normally aspirated engines. Nissan VQ35 heads are priced for the pair.
Specification
CNC Ported/machine finished ports - New OE Castings
Hand blended finish work
Intake 19% Increased Flow (max)
Exhaust 22% Increased Flow (max)
4-angle Inlet Valve job
3-angle & radiused Exhaust Valve job
Valves are lapped
Back-Cut Inlet Valves
Heads are Ultra Sonic cleaned prior to assembly
Heads are Serialized and sport a machined Cosworth logo
+1mm Stainless Steel Intake Valves (1800 degrees max.)
+1mm Inconel Exhaust Valves (2400 degrees max.)
Performance Valve Springs
Titanium Retainers
Hardened Steel Spring Platforms
Knife Edge port divider
Old Jan 4, 2008 | 09:25 PM
nyqueenz's Avatar
Specification
Valves are lapped
Titanium Retainers
That’s what I was talkin about as far as a built engine.. Which I think for the money is a lot better then going FI cause of the fact the power is about the same or more with less money and hassle
Old Jan 4, 2008 | 09:41 PM
Texasscout's Avatar
And you don't loose as much when it gets Hot!
But heck, I'll bet that it cost as much as a new G to get Cosworth to build you a motor. For that kind of scratch, I'll buy a GT-R!
magnetism80
Jan 27, 2016 12:57 PM
alessandro
Oct 8, 2015 09:29 AM
G35-2004-mt6
Sep 11, 2015 04:16 PM
Albanian122
Engine - Exhaust
Sep 5, 2015 11:23 AM
