Test Pipe Install (NEED HELP!!!)
I'm installing my test pipe right now and I got 2 bolts off from the cat. and I can't seem to reach the three flange bolts on the other side of the cat. I read some sites saying I should do it from the top engine bay for a header install, but I'm just doing cat. is there anyway to do it from the bottom? Thanks
How much is radiator fluid and how much do I need, in the event that I need to drain it?
I also tried accesing the 3-bolts from the bottom, but its nearly impossible to break the torque from there. Just go ahead and get an extension and do it from the engine bay.
I tried for like 20 mins, got
called function:TUNED, they told to get it from the top. It took less that a minute to get it lose
All you need is two 36" ratchet extensions. Just make sure you tape them together and go from the top. Takes 10 minutes.
i did mine fron the bottom, the ONLY hard one for me was the top nut/bolt on the header to cat flange the top one, WOW what thing was a bitch you should have seen the contraption i cooked up to get that thing off, you would of laughed not to mention it was prob rusted a lil and thought i was gonna burst a vein trying to torque it loose, every other one came off easy from the bottom
just used extentions for some
