Just installed MREV2.... Reset ECU?
Old Jan 13, 2008 | 06:39 PM
Texasscout's Avatar
I tried the Gas pedal reset in the MREV instructions, but I couldn't get it to work. I REALLY don't want to reprogram all my radio stations (AM/FM/XM), so do you really need to reset the ECU when you install?
Old Jan 13, 2008 | 07:22 PM
citymunky's Avatar
You don't have to reset ECU.
Old Jan 13, 2008 | 09:22 PM
TonyG35DG's Avatar
I installed the 5/16" plenum spacer yesterday and did the ECU reset. Failed the first few tries too. You should try starting the reset sequence while the car is still beeping when you turn the ignition to ON. The instruction says to wait 3 seconds, but if you wait too long you'd miss it. I began the sequence after the 2nd beep.
Old Jan 13, 2008 | 09:56 PM
Texasscout's Avatar
Thanks for the info, but it's running so good now, I'm not sure I want to change anyting!
mike730
Jan 12, 2018 04:25 PM
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
Silver tiburon
Sep 4, 2015 07:17 PM
leli_11
Aug 10, 2015 08:25 PM
kenthung
Jul 21, 2015 05:56 AM
