What makes more power?
Old Jan 20, 2008 | 01:16 PM
Gurveer's Avatar
What makes more power? Mrev2 or a true dual 2 or 2.5 inch exhaust? considering HKS Borla Injen
Old Jan 20, 2008 | 01:27 PM
Jason@Riverside's Avatar
MREV2 w/ Spacer on a REV-UP motor...
the Power to $ ratio is double with the MREV, for the money you pay for the exhaust, you get half the power.
Old Jan 20, 2008 | 01:34 PM
Gurveer's Avatar
thanks jason.
Old Jan 20, 2008 | 03:59 PM
Beebo's Avatar
if your 6mt then md merv2 and 5/16 spacer, intake, and exhaust...
be sure to reset your ecu if you get the mods
btw jason can give you a good deal on the mods
Old Jan 20, 2008 | 07:15 PM
MAZyar's Avatar
I have the 04 car, so I'm assuming that's the non-rev up engine. If that is the case, with my mods, do I still need to reset the ECU?
sorry, I don't mean to steal the thread, I've always had this question and wanted to put it to rest once and for all. Thanks.
Old Jan 20, 2008 | 07:45 PM
Texasscout's Avatar
If you have an 04', you don't need the MREV. Just get a spacer and do the exhaust.
Old Jan 20, 2008 | 07:51 PM
MAZyar's Avatar
wouldnt changing headers give u more hp gains vs changing exhaust??
Old Jan 20, 2008 | 08:03 PM
Texasscout's Avatar
Possibly, however not more than 2-3 hp. You are still going thru the somewhat restrictive stock exhaust. So any gains would be moot.
Old Jan 20, 2008 | 08:43 PM
Skaterbasist's Avatar
Retired SuperMod
For a revup, the spacer + MREV2 makes great power for the money. Non-revup, just go ahead and get the spacer.
If you get headers, might as well get a better flowing exhaust & HFC/TP's in order to take advantage of its potential.
Everything goes hand-in-hand. That's one reason why im doing a full exhaust (headers, test pipes, exhaust). I'll definately need a tune after that though.
If that's too much for you, then go ahead and just get an exhaust paired with tp's/hfc. (The stock cats seem to be the biggest bottleneck in the stock exhaust configuration).
Old Jan 20, 2008 | 09:55 PM
MAZyar's Avatar
if you go test pipes, would you still be street legal??
Old Jan 20, 2008 | 10:20 PM
jonnylaw's Avatar
No.
Old Jan 21, 2008 | 01:07 AM
GrayG35's Avatar
get testpipes and spacer. you wont need a tune or ecu reset.
Old Jan 21, 2008 | 01:46 AM
Retired SuperMod
Test pipes lean out the AFR mixture significantly to the point that, if you have enough breathing mods, you will definately need a tune.
I only had an exhaust, spacer, & intake prior to installing my test pipes. And when I did, it leaned out my mixture well enough that I could definately feel a loss of power because the ECU was retarding timing (rev-up).
PS. An ECU reset has nothing to do with an actual ECU reflash/tune.
Old Jan 21, 2008 | 01:48 AM
solopresident's Avatar
teamsolo.net im-integline
im going to run Fast intentions exhaust (got it on lready) and their high flow cats. thinks its the saafest route for the po po's in cali.
Old Jan 21, 2008 | 01:54 AM
MAZyar's Avatar
how about if i only have the spacer. do i need to do the ecu tune? i think at one point, i reset my ecu, would that cause a loss of hp??
how does one tune the ecu? and for how much?
