Best Intake Combo
Old Feb 10, 2008 | 07:27 PM
GMoNeYAir23's Avatar
Best Intake Combo
Hello..I just got my g and like my previous car I want to start putting some stuff in it right away. It is an 03 w/ 6MT. My question is, what is the best intake setup? Stillen z-tube and jwt pop charger(why is called this?) Or stillen z-tube w/ stillen CAI, or Stillen z-tube w/ stock air box w/ K&N filter. Also I plan on putting NGK Iridium Plugs, royal purple or eneos oil, k&n oil filter, and the plenum spacer(1/2 or 3/8), AMS carbon-ceramic brake pads, and mabey a SS clutch line to start...Is that a good start or do you suggest other products that would be better for this car? I know its alot of questions but just trying to see what is best for the G.
Old Feb 10, 2008 | 07:33 PM
DRA-G35-ON's Avatar
I got the Stillen + Z Tube. Pop charger looks real bad to me... I didn't get a plenum spacer yet, so can't help you there but check out MotorDyne
Old Feb 10, 2008 | 07:42 PM
kbmoney's Avatar
I advise you get the ztube w/ JWT pop. It looks and sound good
Old Feb 10, 2008 | 08:54 PM
Andy2434's Avatar
When all is said and done . . . You will be well served with simply a Z tube and a high flow drop-in filter, such as a K&N or an Amsoil.
Old Feb 10, 2008 | 09:51 PM
ye thats what I think Ill end up doing
Old Feb 11, 2008 | 11:16 PM
any other opinions?
Old Feb 17, 2008 | 11:14 PM
bump for more info
Old Feb 17, 2008 | 11:33 PM
codemonkey's Avatar
I wanted to keep a clean/stockish look under the hood so I got the Stillen intake and z-tube with Motordyne 5/16th spacer. The Stillen intake looks like it belongs in the car and the 5/16th spacer lets you keep the engine cover on quite nicely (although there are mods to allow keeping the cover with larger spacers). IMO the poop charger looks like...poop.
In any case, don't expect huge gains from any of these mods. In our cars they are mainly for sound and/or look.
BTW, there are probably about 12 brazilian threads on this topic so you won't get many responses to this thread. Search is your friend.
Old Feb 17, 2008 | 11:54 PM
Beebo's Avatar
Motordyne 5/16th spacer is really the only thing you will see good gains from... and a z-tube will help as well.. its less restrictive
z-tube on the left g-tube on the right
short ram intakes like Stillen high flow air box/z-tube
are mostly for sound very little hp/tq gains... not enough to notice
o and slightly better mpg too
cold air intakes are not good most lose power
Old Feb 18, 2008 | 10:09 AM
Thanks for the pics, if I buy this...it comes w/ everything you have installed (the person in the above post)http://www.stillen.com/product.asp?i...odel=G35%202DR
Also the search button is coming up w/ any luck for me
Old Feb 18, 2008 | 11:31 AM
clifftrail's Avatar
If your interested I have a Z-tube and K&N drop in that I'll sell, took it off to install a Vortech and I'm not going to use it anymore. $100 + ship, PM me with your zip if your interested.
Old Feb 18, 2008 | 01:46 PM
VQdriver's Avatar
so i got a K&N panel filter to replace my oem infiniti one. upon removing the stock dirty one i noticed that the oem intake box employs a small velocity stack such as the one you might get with the stillin or JWT intake which makes me further doubt the design advantage of either short ram intake for the money. nissan did as much as they could to achieve the best cool airflow coming into the intake.
Old Feb 18, 2008 | 02:05 PM
nismo240r's Avatar
apologies for the dirty engine bay. . .but this is with MREV2, 5/16" spacer, z-tube and JWT pop-charger . . .very happy with this combo, going to be getting it tuned here pretty soon. . .
Old Feb 18, 2008 | 02:51 PM
M@rCo's Avatar
What he said.
Old Feb 18, 2008 | 03:39 PM
ye idk if I want to drop like 255 for the stillen intake filter...especially if the only thing it is going to do above using the z-tube an a K&N drop in filter is sound...thnks for the info
