1st gen sedan dual exhaust complete.
Old May 23, 2008 | 12:00 PM
  #151
fronypony's Avatar
Originally Posted by ttrank
I gave in and put the evap box back on but moved it to the spare tire well. I extended the hoses and wires for the valve and pressure sensor then put heat wrap on them since they run right over where the exhaust is.
How did you extend them? Did you cut into them and add more length to them or did you replace the tubes altogether?
Old May 24, 2008 | 01:43 PM
  #152
ttrank's Avatar
Grocery getter
I ran new hoses and extended the wires.
Old May 24, 2008 | 01:44 PM
  #153
ttrank's Avatar
Grocery getter
Originally Posted by OCG35
what material are you using?... have you looked into b-quiet? Its pretty light (compared to comparable products) and has good sound deadening/dampening/absorbing properties...
I have some Stinger Road Kill pro here and was going to order some of the B-quiet.
Old May 27, 2008 | 04:41 PM
  #154
fronypony's Avatar
Hey Tim, to run the new hoses, when you 'unlugged' the old/original ones from the evap canister, was there gasoline in the hoses, or are they just for gases/fumes? Still wating for pics when you get a chance. Thanks
Old May 27, 2008 | 07:22 PM
  #155
ttrank's Avatar
Grocery getter
There may be a little gas (drops) in there. It's mainly just for fumes.
I still have to order the B-quiet so it may be a little while. I've been so busy at work and with the family my car has been on the back burner.
Old May 27, 2008 | 08:24 PM
  #156
OCG35's Avatar
okay, okay... I'll help you out and baby sit the car for a couple weeks
Old May 27, 2008 | 10:50 PM
  #157
fronypony's Avatar
Thats cool, no rush, just making sure you didn't forget.
Old May 28, 2008 | 03:16 AM
  #158
ttrank's Avatar
Grocery getter
Sounds good, as soon as my garage is tired and needs a break I'll call.
Old May 29, 2008 | 10:25 AM
  #159
fronypony's Avatar
Here are a couple pics:
Hey Tim, in the second pic, where did you get that heat wrap/shield? I checked at Advance Auto Parts with no luck. And you have no heat problems with the exhaust and the evap hoses/wires? Also, with your evap box in the spare tire well, your spare fits over the box? I have OEM 17's and I tried it and it doesn't work, do I have to have a 19" rim? Thanks
Old May 29, 2008 | 11:30 AM
  #160
ttrank's Avatar
Grocery getter
The heat wrap I had left over from the turbo install because I put a ton of it up front. I got it online a long time ago.
I'm not sure if an 18" will fit or not. I think it would.
Old Jun 6, 2008 | 08:26 PM
  #161
ttrank's Avatar
Grocery getter
I'm thinking about changing out my mufflers for a pair of HKS carbon Ti.
Thoughts?
http://www.hksusa.com/products/?id=1733
Old Jun 6, 2008 | 08:40 PM
  #162
psedog's Avatar
Back in SD**
Those will look tight, but I don't know how they sound. Time to search youtube
Old Jun 6, 2008 | 08:48 PM
  #163
psedog's Avatar
Back in SD**
Here it is on a 350z single exhaust though. Sounds alright, not enough bass in it, like the dual hi-power. (could be the vid though)
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/1o9abxF7A3k&hl=en"></param><embed src="http://www.youtube.com/v/1o9abxF7A3k&hl=en" type="application/x-shockwave-flash" width="425" height="344"></embed></object>
dual hi power
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/BdIDYw5Sa7c&hl=en"></param><embed src="http://www.youtube.com/v/BdIDYw5Sa7c&hl=en" type="application/x-shockwave-flash" width="425" height="344"></embed></object>
Old Jun 6, 2008 | 09:06 PM
  #164
fronypony's Avatar
Those cans look nice (no punn intended) too bad you won't really be able to see them under the car.
Old Jun 6, 2008 | 09:32 PM
  #165
ttrank's Avatar
Grocery getter
Those are different than the universal ones I'm looking at. Between the muffler, larger pipe and lower compression mine will be deeper.
