Question about ECU
Old Feb 28, 2008 | 12:22 AM
Anvar's Avatar
Exclamation Question about ECU
Hello I'm from Russia , my english is bad, i've got some questions.
There is not enough information about G35 here (in Russia)
I have G35x 2007? i want to increase power
I want to replace intake and exhaust system but i was told that without new ECU (program) it's Inefficiently. Is it true? Where can i get new program?
I want to put these things
http://www.stillen.com/product.asp?i...odel=G35%204DR
And what's the better stuff - stillen, HKS, a'pexi, 5zigen or greddy? I don't want to have too loud exhaust
Old Feb 28, 2008 | 12:38 AM
BlueDevilBAMF's Avatar
There are several Russian-speaking members on here who may be able to help you out... As far as reprogramming the ECU, there are places that can ship programs you can install with your computer (UpRev Osiris, for example). Not sure if they ship internationally, but I don't see why they wouldn't.
Good luck!
And your best bet with figuring out which exhaust you want is to either search YouTube videos, or listen to sound clips. This website's sound clips might be a good place to start:
http://g35turbo.com/Exhaust-Sound-Clips.html
Old Feb 28, 2008 | 12:47 AM
Anvar's Avatar
i think there are no such computers in city i live in, maybe i can buy chip as i buy intake and exhaust? it would be much easier for me
thank u
Old Feb 28, 2008 | 01:02 AM
Actually the Osiris is a CD that comes that you load onto your personal computer... you can customize it the modifications you have done. They have up to 5 different maps you can have all on the same software. It plugs into your ECU via a USB cable from you computer with the output directly to your ECU.
Old Feb 28, 2008 | 02:00 AM
Anvar's Avatar
thank you! i 'll try. Do YOU think that puting exhaust without new ECU will not be effective for power?
Old Feb 28, 2008 | 10:42 PM
OCG35's Avatar
guys he has an 07 G35x... wouldn’t that be a sedan?... which means its the HR... I'm not sure the ECU tuning has been accomplished on the HR yet... I know TS has been working on it (they may be offering now?)… but I don’t think UpRev is ready yet.
Old Feb 28, 2008 | 11:43 PM
Anvar's Avatar
What does HR means?
Old Feb 29, 2008 | 12:24 AM
Good point... UpRev probably isn't available yet.
HR is the newer VQ engine from Infiniti. '03-'06 were the VQ35DE, now it's the VQ35HR.
Old Feb 29, 2008 | 12:38 AM
SlooberTooth's Avatar
Not sure about HR, but THere have been a bunch of dyno test which show bolt on mods losing some power w/o a tune or ecu flash. I think to more bolt-on mods you do w/o a tune, the more potential there is of losing performance. So I would do your mods, then get a flashed ecu from AAM or technosquare or something similar to that like osiris.
Old Feb 29, 2008 | 01:01 AM
As far as bolt-ons and added performance, I have a Stillen CAI, Z-tube, AAM angled plenum spacer, Fast Intentions dual cat-back and high flow catalytic converters, and my car is much, much faster than stock - both in feeling and actual performance. As far as the '07 G35X, however, don't know, but if you do enough bolt-ons you'll see again with or without a flash. A flash, of course, will optimize and increase the gains.
Old Feb 29, 2008 | 04:41 AM
Anvar's Avatar
i want to put Hi-Flow Dual Intake Kit, Hi-Flow Catalytic Converters and Exhaust Systems, all made by stillen. How do you think, will my car go faster or only become louder?
Old Feb 29, 2008 | 11:02 AM
Realistically your car should be both louder and a bit quicker if you do all three of those modifications. A reflash would, of course, make it a bit quicker yet.
Old Feb 29, 2008 | 11:06 AM
GreenGoblin's Avatar
The goblin resurrection
did the dual pop charger come out yet for the HR that would be some thing to look at also the stillen exhaust sounds sweet. I dont think that there is any computer/ mods for the HR yet I could be wrong tho.
Old Feb 29, 2008 | 11:54 AM
OCG35's Avatar
Basic bolts on are almost all breather mods… at some point you end up running lean… this is what ends up killing power – the ECU pulls timing to prevent knock… intake and exhaust generally won’t lean you out to much – even adding a plenum or spacer usually keeps it okay… but once HFC or test pipes and/or headers are installed (with intake, exhaust, plenum) often times the A/F is too lean and the car becomes a slug.
It’s all moot though because from what I can tell the OP has an HR sedan so his only real option is Stillin’s intake and an exhaust… that won’t do much to the A/F and probably not a lot for power (maybe a little)… as time goes on I’m sure there will be more performance stuff available for the HR.
Old Feb 29, 2008 | 12:22 PM
I've got I/E/P and HFCs and haven't noticed the car running lean at all (from a driver's perspective). After installing the HFCs and exhaust, I've put on a few hundred miles and my mid-range acceleration is much improved.
