My G35 Sedan Custom Exhaust...
Old Mar 7, 2008 | 12:08 PM
Eric@TCGMiami's Avatar
Smile My G35 Sedan Custom Exhaust...
Well Guys/Gals I am mostly on Frenzy but thought everyone should see this since I know alot of Sedan are here as well...
Well after a long while with the midpipe being a 2.25 to 2.5 i decided to open it up a bit.
Exhaust as follows:
Top Speed Pro 1 Headers (Heat Wrapped)
Stock Cats
Top Speed Pro 1 Y-Pipe 2.25 to 3 inch
Custom 3 Inch Crush Bend with an Extreme Technologies Racing Muffler (NHRA Approved)
HKS Legamax Muffler
The HKS has a 3 inch flange and it reduces to 2.5 smoothly.
You can notice in the pics the mid pipe looks immensely bigger than the HKS, yet incredibly enough NO RASP!
Butt Dyno:
Car lost torque down low but i can feel the transition up top, pulls much nicer, rev's a bit quicker since the restriction is not as bad as it was.
Noise level in the cabin is about moderate, with the radio @ 12-14 you can not hear the exhaust only the intake.
I am awaiting the Crawford Z HFC's and I will revise this thread once its done.... as usual dyno's are pending!
For now here is a video clip.
and some pics
Mid-Pipe muffler used:
http://www.extrememufflers.com/products.html
1010-3030
Old Mar 7, 2008 | 12:13 PM
Jeff92se's Avatar
Red Card Crew
I'm not sure of the benefit of opening it up to 3" to neck it down to 2.5" again.
Would sure like a dyno sheet if possible. With the auto, I'd hate to give up any more low end torque with our crappy ign timing maps below 3000 rpm
Old Mar 7, 2008 | 01:10 PM
Its not a sigficant loss but i mean you can feel its a loss...(drive 100miles per day and you can tell when something is out of place)
I am pending the HFC's and then a dyno followed by a T/S Reflash
Old Mar 7, 2008 | 02:45 PM
5150DS's Avatar
3 inch is kind of a large jump from 2.25 inches. I figure there is a reason Fujitsubo and Tanabe only go to 2.75 inches. Ohter than the size it looks good. I will have to wait until after work to listen to clips (you tube is filtered by firewall).
Old Mar 7, 2008 | 03:20 PM
Its only a small section going 3 inch then back down to 2.5.... If anything i think this helped the mid-range - top end alot more... before the car would slow down up top now it just wants to keep going
Old Mar 7, 2008 | 07:57 PM
5150DS's Avatar
Where did you get the muffler? Is it the HKS rear section commonly used by sedan owners?
Old Mar 9, 2008 | 08:29 PM
Got it from Darren @ IntensePower.com
http://intensepower.com/hksspexforg3.html
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
