is it possible to have vacuum leak ............
Old Mar 16, 2008 | 12:51 PM
Klubbheads's Avatar
with idle being rock solid????
Old Mar 16, 2008 | 01:16 PM
IrockAG35's Avatar
Ohio G Club moderator
not sure, but my cpv line was ran to my vaccum line off my procharger, it came off...i couldnt find out where it was ran so i put a catch can on it..my idle seems normal..i would think there is an opening on my vaccum line now
Old Mar 16, 2008 | 02:19 PM
jonnylaw's Avatar
I'd like to know this too and not have to resort to using a vac guage.
Old Mar 16, 2008 | 04:15 PM
DaveB's Avatar
What's the problem? Why do you suspect a leak.
Old Mar 16, 2008 | 05:03 PM
jonnylaw's Avatar
I have a cosworth plenum, lol.
Old Mar 16, 2008 | 06:14 PM
Klubbheads's Avatar
other people are, im not at all. I am convinced that i don't have a leak because i am not seeing any decline in power or anything like that. I just want to know if its possible to have a leak and have the idle be steady at all times.
Old Mar 17, 2008 | 12:25 PM
Klubbheads's Avatar
bump/
Old Mar 17, 2008 | 03:50 PM
DaveB's Avatar
Yes, it is possible to have a vacuum leak and still have a steady idle. The way this happens is there is a bad seal that is fine under idle vacuum (18-20 hg), but under part-throttle, a leak is caused by by the rising vacuum (22-26 hg). At full throttle, there is no vacuum made therefore there would be no vacuum leak. Basically what you'd get is a car with a normal idle and normal WOT performance, but really crappy normal driveability. The acceleration could be really choppy and a CEL would most likely be thrown (probably a MAF CEL).
It is also possible to have crappy WOT performance if the leak is occuring around the intake tube or anything past the MAF that has stress on it when the engine rocks in it's mounts.
Old Mar 17, 2008 | 03:54 PM
jonnylaw's Avatar
What is the best way to check for vacuum leak under part-throttle besides vac guage?
Old Mar 17, 2008 | 04:06 PM
g35rcr's Avatar
it could be an exhaust leak as well either at the exhaust manifold or after the cats
Old Mar 17, 2008 | 04:08 PM
Jeff92se's Avatar
Red Card Crew
IF it's a vacuum leak at the manifold, it would still be leaking at idle. Idle represents the high vacuum pressure. You could try spraying WD40 around the seal and see if the idle changes. ie.. goes up = leak. Nothing = no leak.
Old Mar 17, 2008 | 04:16 PM
jonnylaw's Avatar
thanks! I'll try that. Honestly, I don't believe I have a vacuum leak with the Cos plenum, everything is running fine, I may just do this for peace of mind.
Old Mar 17, 2008 | 04:17 PM
Klubbheads's Avatar
Whoever told me this was suspecting a manifold leak. Thanks for the responses. I will try that wd40 trick see what happens.
Jeff how accurate is this method?
Old Mar 17, 2008 | 04:19 PM
jonnylaw's Avatar
Is using some soap and water around the seals and looking for bubbles another method?
Old Mar 17, 2008 | 04:20 PM
Jeff92se's Avatar
Red Card Crew
I dunno. It's just a hick/cheap method to try. FI guys will spray soapy water onto their connections to see if they have boost leaks. But don't do this on a NA engine! lol.
