Pop Charger/Z-tube problem, please help!
Old Mar 28, 2004 | 07:25 PM
Paul1082's Avatar
So,
I put in my ztube pop charger combo, and it was working great. I drove around for about 30 min, then went to do some work. Went out to drive to a trail for a run, and the damn car shut off going about 65mph!. Tried to start the car, and no luck. I checked my install, it was correct. I had to put the stock intake back on in order to start the car. What is going on here? Thanks for any help you can give me.
Old Apr 1, 2004 | 07:53 AM
wjfm1's Avatar
Re: Pop Charger/Z-tube problem, please help!
Try resetting the ECU.
2003.5 G35C BL/GR, NAV, PREM, AERO, TINT, SPORT, Splash, V1
Old Apr 1, 2004 | 10:25 AM
rrowen's Avatar
Wow, that is wierd. I've had my ztube/popcharger on my '03c6mt for months & never had that happen. Plus, I never reset my ECU. When you checked your install, is the vacuum hose still connected & hose not pinch? Its hard to see the hose. Even if hose fell off, I don't think that would cause your problem. Another thought is that the MAS connection is very close to the aluminum pipe running for the airconditioner. Maybe the MAS connection was touching the pipe & shorting out under speed. Be patient, more will respond with their opinion.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
mattdg35
Sep 14, 2015 11:28 AM
ChrisAult2004
Sep 11, 2015 10:33 PM
jbmw002
Sep 10, 2015 12:54 AM
Jnm07
Sep 5, 2015 01:16 AM
