This happened to anyone?
Old Apr 1, 2004 | 11:08 PM
jbt930's Avatar
After I installed the Stillen catback, you can see below the rest of the mods, two diferent times the car stalled. It only did it when the rpms were above 3-4000 and when I put the clutch in and held it in. With that being said, there was quick drop off in the rpm but the car would not "catch" itself, the rpms seem to just fall through to zero. The car never "studderd" just shut down. I have tried to repeat this but can not. I think it will happen again. Not at all blaming the exhaust but having the stock & greddy evo exhausts w/ mods listed I never had trouble. Maybe the test pipes? Don't care much for their sound anyway. Thanks for any comments or suggestions.
04 G35S 6MT DG
Crawford Plenum-Stillen Catback-Helix Pipes
Stillen CAI-Z Tube-Grounded-Clear Corners
Old Apr 1, 2004 | 11:18 PM
Gsedan35's Avatar
Re: This happened to anyone?
Do a ecu reset and see what happens. It's common for test pipes to throw a CEL (check engine light), and to have raspyness to them. But I have never heard of them shutting down a car. However, the type of stall you got leans me to the ecu being on a difficult learning curve to your new mods. Reset and go from their.
"All that's necessary for the forces of evil to win in the world is for enough good men to do nothing.”
Edmund Burke
G35 6mt
jbt930's Avatar
Also, my car idles @600 (no AC) -not sure if with this current setup that this may be a little low??
04 G35S 6MT DG
Old Apr 1, 2004 | 11:21 PM
jbt930's Avatar
Thanks for quick reply!! I did the ECU reset. Maybe it needs more time? Just installed yesterday.
04 G35S 6MT DG
Old Apr 2, 2004 | 01:08 AM
klg35's Avatar
while you're at it, make sure all the connections/bolts are tight in the intake tract.....especially after the maf sensor. my 00 maxima did that and sure enough, there were some loose clamps in the intake after the maf sensor, tighten them down and didn't stall anymore.
04 Black Sedan 6mt / front blinker mod, z tube+k&n panel filter / 18" r/h c2s w/khumos 235/40zr18 / stock airbox mod / s-teins / crank pulley / pre-muffler, what pre-muffler?
[image]url[/image]
Old Apr 2, 2004 | 01:17 AM
humanRESEARCH's Avatar
600 RPM is nothing to worry about...That's actually very efficient when dealing with a V6
"All the Power in the World resides in the Eyes..."
Freeman186
Sep 6, 2023 10:07 AM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
