Xo2 exhaust tip **solution** ~xo2 owner ONLY!!~
Old Mar 25, 2008 | 07:23 PM
ELE's Avatar
ELE
Xo2 exhaust tip **solution** ~xo2 owner ONLY!!~PICTURE UPDATED***
***PICTURE UPDATED MAY02,08***
VERY EASY INSTALLATION, ONLY DRILL ONE HOLE FROM THE INSIDE~ AND DONE~.~
the purpose of this thread is for xo2 owner who willing to spend a little money and get their tip turn out little bit nicer~.....
not to discussing whether or not to get the xo2 exhaust~~ thank you
i bought these tips on ebay, yes again EBay....wahahha, they are made by Topspeed~ looks very nice and high quality, very nice welding
i will try to post more picture after the installation~ but remember, before ur purchase, be sure that they are named as **100% Titanium**(more expensive) , not the **Titanium look**(less expensive) which look almost the same as the xo2 stock tip~....
they also have other sizes, 4 inch and 4.5 inch, for Xo2 owner should get 4.5 inch...so remember to pick the right one~~
here is the one i bought: http://cgi.ebay.ca/Universal-115MM-4-5-Slide-on-100-GeniuneTitanium-Tip_W0QQitemZ300207770450QQihZ020QQcategoryZ33630QQtcZphotoQQcmdZViewItemQQ_trksidZp1742.m153.l1262
here is the one that cheaper which they call **Titanium look**:
http://cgi.ebay.ca/Universal-115MM-4-5-Slide-on-Titanium-Look-Tip_W0QQitemZ280209560000QQihZ018QQcategoryZ33630QQtcZphotoQQcmdZViewItemQQ_trksidZp1742.m153.l1262
Old Mar 25, 2008 | 07:27 PM
Calvin's Avatar
Overglorified Altima
wow, that's a fantastic deal!
hell, i might even buy some for my HKS in case I ever scratch my tips on an incline.
good find!
Old Mar 25, 2008 | 07:34 PM
SteveBlake's Avatar
DEFINITELY gotta get these, but will you just drill holes in them to put'em on?
ELE's Avatar
ELE
yeah they r very nice indeed, however, there is a bad thing which i dind't mention yet, is they got bunch of holes at the bottom of the tips~ i think 5 holes in 4.75 inch length i willl take some picture, hold on~
that's why im still thinking should i fill the hole or just leave it=.=., i did asked them before purchase, they said they are pre drilled by topspeed~. nth we can do about it...
here is the picture
Old Mar 25, 2008 | 07:38 PM
srsly's Avatar
could these go on the OEM exhaust?
GreenGoblin's Avatar
The goblin resurrection
not bad at all
Old Mar 25, 2008 | 07:44 PM
w0ady's Avatar
fgc moderator
nice! but im guessing you see the holes if you look inside the exhaust which is rare. so are you drilling holes in the side and replacing your xo2 tips with these?
edit: also how does the length compare? do you mind taking some side by side pics of the old/new tips? thanks.
Old Mar 25, 2008 | 07:47 PM
ELE's Avatar
ELE
i will try to do that when i do the install, but they are little bit shorter
they said they are angled so the short side is 4inch, the long side is 4.75inch,
Old Mar 25, 2008 | 07:53 PM
O HELLA OEM's Avatar
i would like to know too
Old Mar 25, 2008 | 07:56 PM
ELE's Avatar
ELE
i guess u can put it on top of the oem tip, but it will look weird tho=.=...since they are a lot bigger than stock tip~...or i doubt they could fit by just drill a hole and fit nicely
Old Mar 25, 2008 | 09:58 PM
App6MT's Avatar
Littering and...
This is the best find. I was going to create new tips for my XO2 but this is such a great deal it wouldn't even be worth it, even with the holes on the bottom (you can't see them anyways)!
Great find!
Old Mar 25, 2008 | 10:09 PM
nikkaitsme's Avatar
Nice find
Old Mar 26, 2008 | 12:51 AM
shipsaeki's Avatar
anyone know how big the tip is for invidia g200?
Old Mar 26, 2008 | 12:55 AM
Strtsk8r321's Avatar
i hope some one tries it one OEM exhaust. I would get em if it worked right
edit: maybe the 4" ones will fit?
Old Mar 26, 2008 | 12:58 AM
Calvin's Avatar
Why don't you go measure your stock exhaust tips...?
