Addin A Plenum Spacer To My 04 Coupe
Old May 4, 2008 | 01:09 AM
amoreno35's Avatar
Ok Guys I Have A Question? I Have An 04 Coupe. And I Put The Mrev2 In My Car. And I Noticed A Little Difference In Power And Sound. But Anyways I Now Want To Put The 5/16 Spacer On. Will I Loose Power And Sound If I Do This? Or Should I Take Of The Mrev2? Can I Have Both On There? Thanks
Old May 4, 2008 | 02:36 AM
amoreno35's Avatar
anyone?
Old May 4, 2008 | 09:06 AM
LMG_35C's Avatar
I have both and felt that each added small gains in different areas of hp/torque curve. Thing is you'll probably not get maximum benefit without some type of improved tune. Some are concerned could cause lean condition if you also have exhaust mods so I'm waitng on HFC's before adding either the Cobb or UpRev ECU mod.
Old May 4, 2008 | 10:37 AM
Hydrazine's Avatar
If your engine is running healthy it will do about 4-6 more HP.
Check out this link:
https://g35driver.com/forums/engine-drivetrain-forced-induction/214040-mrev2-04-coupe.html
Tony
laksjd84
Steering & Suspension
14
Aug 8, 2015 11:47 AM
deathsupport
Canada
Aug 2, 2015 10:13 AM
xplosive1
Aug 1, 2015 03:01 AM
Ninjay16
Jul 20, 2015 01:21 AM
