question to those who have personally installed headers
Old May 14, 2008 | 07:27 AM
rpm06g35's Avatar
Looking for info on header installs. We will be installing both clutch /flywheel and crawford headers. My question is about the header bolts. I realize they are studs and I also realize they are very long. I just looked at the arp website and will have to get measurements on the bolts and header flange to get this right. Do you guys who have installed your own headers feel that if you had shorter manifold studs it wouldve been easier to install your headers? let me know I tried searching and came up with squat later mike
Old May 16, 2008 | 11:21 AM
rpm06g35's Avatar
got the mesurements m10x 1.25. I dont know the length yet. It is 25 or 30 mm so I ordered 15 of each from arp with washers. I will post up info with pics. I feel this will make header install easier since These are bolts and not studs. Thanks anyways guys. later mike
Old May 16, 2008 | 11:31 AM
GreenGoblin's Avatar
The goblin resurrection
Mike when I did mine the hardest part was when a stud came out getting the stud back in without cross threading it. If I were to do it all again I would pull the motor in a couple hours instead of cutting up some tools breaking knuckles and would remove alot more stuff to get proper clerance
RA102223
Aug 15, 2015 09:24 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
joedaddy1
Jul 28, 2015 02:58 PM
yosip1115
Engine - Exhaust
Jul 22, 2015 01:47 PM
