Coupe Magnaflow Custom Dual
Originally Posted by theGcar
a couple questions klubbheads,
how much would that setup set you back?
and how loud are the magnaflow mufflers? do you have a sound clip?
Custom dual exhaust from Magnaflow....!
Putting this system together you definitely want to use the crossover which
will equalize the sides. What mufflers you use should be suggested by an
expert like my Son at Magnaflow....Chris 1-800-990-0905. Let him know you
want the muffler placement ahead of the rearend. You'll need a very flat
oval muffler for ground clearance....G/L!
Gary
Gary
this is the other idea i had, a little more simple i guess. It allows me to buy an aftermarket y-pipe instead of having to fab something up, so it saves a little bit of fab-time and cost possibly.
It uses a dynomax SS-ultra-flo 3in inlet to dual 2.5in outlets. its of a straight thru design, so no chambers like you get in other muffler designs. I would prefer a true-dual setup, but i really dont need it...im going for something thats light/performs well, sounds really good (to me at least) and comes in at bargain compared to other name brand systems.
I would think though that if the bridge pipe between the y-pipe and the center muffler in the above design was short enough it would essentially be very close to the effect of a X-pipe...in theory at least, I dont know if there is enough room under the car to have a muffler where most y-pipes come to an end.
To my knowledge its not a continuous flow from the exhaust, its rapid pulses that seem to be continuous. so if that bridge pipe was short enough from the y-pipe to where it splits again the muffler, wouldnt that be close enough? If not, i think the difference would be marginal. If it wasn't too expensive I suppose I could try to make the design I have more modular and try to test them both once built...which I may even be able to do just digitally with my computer software, but I do not have the flow characteristics of our cars to do the testing with FEA.
If it would please anyone I suppose I could just test the two different designs under constant flow and see which one would work best in a "simulated lab-environment". Might take me a few weeks though, so we'll see.
This is what I am going with after talking with Chris at Muffler Tech in Sacramento.
Summit Racing X-pipe kit $67.95
Magnaflow 10435 Mufflers (4) $68 each
The muffler design is two 10435s side by side behind the x-pipe followed by two 10435s separated by 6 inches then pipe the rest of the way. I do not have a sound clip so I am taking a chance on that.
Originally Posted by idrive_MD
Running without cats? well keep us posted and get us a vid when its done please.
djreinx
Engine - Electrical
Dec 10, 2015 01:48 AM
THMotorsports
Midwestern
Jul 22, 2015 10:27 AM
