Plenum Spacer????
Old Jul 25, 2008 | 06:03 AM
  #31
jimmykce1's Avatar
Originally Posted by rob40wilson03
tony, i was looking at pictures of the isothermal spacer on your website.... which piece is the coolant control valve? is it the top left piece with the little screw in the middle of it?
also, im guessing that in the NC/VA area I would be better off with the copper isothermal one since in spring and fall the night/day temperatures sometimes vary between 30s/70s respectively?
thanks
I am in Virginia Beach Area and have a ISOthermal spacer. Have had no problems. If your in northern VA you may want to get the copper since it gets colder.
Old Jul 25, 2008 | 07:45 AM
  #32
Hydrazine's Avatar
Originally Posted by Da_ReD_G
so being in fl... knowing its hot...I never thought to close the valve switch **** i forget where exactly its at to to be honest... WOULD it hurt if i leave it open ????
The valve is just underneath the air intake tube on the driverside side of the plenum.
For places like Florida, you can close the valve and leave it off... unless in some rare case it got unusually cold there.
...Hell will freeze over before Florida ever gets cold though.
Old Jul 25, 2008 | 02:25 PM
  #33
Da_ReD_G's Avatar
so it wouldnt hurt if i lef tit open or anything ?
Old Jul 25, 2008 | 07:58 PM
  #34
Hydrazine's Avatar
Absolutely no problem at all. But it is better if it is closed during the warm season. Your plenum will run a lot cooler.
Old Jul 25, 2008 | 09:53 PM
  #35
dev1983's Avatar
Hydrazine:
Is there going to be a sale anytime soon on the spacers?
Old Jul 25, 2008 | 11:38 PM
  #36
Hydrazine's Avatar
Give me a PM.
Old Jul 26, 2008 | 03:21 PM
  #37
350gt man's Avatar
dose anyone know if the iso thermal spacer comes with all the hardware nessacery to complete the install
Old Jul 26, 2008 | 03:27 PM
  #38
Da-G-SpoT's Avatar
No, its just a piece of metal..... yes it comes with everything, look at Tonys website. It brings everything you need, even threadlock if you want to use it.
Old Jul 26, 2008 | 04:23 PM
  #39
350gt man's Avatar
okay thanks
Old Jul 28, 2008 | 01:13 AM
  #40
Hydrazine's Avatar
Originally Posted by dev1983
Hydrazine:
Its on now.
Old Jul 28, 2008 | 04:56 PM
  #41
astonv12's Avatar
What about the 1/2 iso spacer? and is there any install shops that you guys recommend in the so cal area? I don't trust myself with installing this.
Old Aug 15, 2008 | 06:49 PM
  #42
maomao's Avatar
I'm curious about the 1/2 spacer too. As compared to the 5/16 what are the pros and cons of each? Seems like the 5/16 is much more popular.
Old Aug 16, 2008 | 12:23 AM
  #43
Hydrazine's Avatar
The differences are shown in great detail in the dyno section of our website.
Basically, the 1/2" spacer makes more top end power and the 5/16" makes a higher average power.
What is best depends on how you drive.
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
prinny
Nov 22, 2015 11:07 PM
w4kj4k
Oct 2, 2015 07:57 PM
thechitoguy
Oct 1, 2015 05:25 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
