Motordyne 1/2" Spacer with Copper ISO Thermal Question
Old Jul 15, 2008 | 11:07 AM
ONEmike's Avatar
So i picked up a used Motordyne 1/2" Spacer with Copper ISO Thermal, but it didn't come with the isothermal gasket or the gasket for the throttle body to put the copper in. do i need these parts, or are the gaskets enough?
let me know thanks!
Old Jul 15, 2008 | 01:07 PM
Hydrazine's Avatar
The iso thermal system needs the Aramid gasket to work.
Otherwise, you should probably use a new gasket on the throttle body.
The old one is likely to seal, but there is a chance it may not. If you do, you'll know for sure once you try it.
Old Jul 15, 2008 | 03:33 PM
ONEmike's Avatar
So would it be safe installing the following
Spacer
Copper throttle body spacer
New Throttle body gasket
and no aramid gasket
Old Jul 15, 2008 | 09:26 PM
Hydrazine's Avatar
Absolutely.
EDIT: On the condition that you don't unbolt your lower plenum in the process. Unbolting/rebolting is what disturbs the stock metal gaskets.
jbelf23
Forced Induction
Oct 24, 2015 12:32 PM
CoupeObsession
Aug 17, 2015 01:05 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
sick_sixspeed
Jul 20, 2015 10:25 PM
