difference between motordyne's 5/16'' and 1/2'' plenum spacer
Old Aug 26, 2008 | 11:19 AM
Da_ReD_G's Avatar
can someone whos experienced or knowledgable please explain to me difference between 5/16'' and 1/2'' plenum. performance wise which is better and comparison?
Old Aug 26, 2008 | 11:23 AM
lekker_droom's Avatar
It's spelled out pretty clearly on MotorDyne's website. Did you read the product descriptions on there yet?
Old Aug 26, 2008 | 01:52 PM
Da_ReD_G's Avatar
nope
Old Aug 26, 2008 | 02:34 PM
twin001's Avatar
Yep
http://www.motordyneengineering.com/dynos.htm
http://www.motordyneengineering.com/techinfo.htm
Generally, the 1/2 inch spacer will yield more power up top while the 5/16" spacer will give you more midrange power.
Old Aug 26, 2008 | 02:40 PM
Shakuya88's Avatar
Unless you are a track only car get the 5/16's, it has more useable power
Old Aug 26, 2008 | 02:48 PM
gary c's Avatar
If you look closely at the graph the 1/2" spacer will give you more HP through
out the RPM range! (that's why I installed) Down side....you'll lose the OEM
engine cover. (no longer fits) Now you'll have a chance to have another mod!
Gary
Old Aug 26, 2008 | 02:52 PM
twin001's Avatar
That's kinda why I went with the 3/8" PL spacer, the thickness is between the 5/16 and 1/2.
On another note, I noticed on MD's webpage he has knocked the prices down on the 5/16" quite a bit
Old Aug 26, 2008 | 04:19 PM
Da_ReD_G's Avatar
Gary
why not just get longer bolts or something to hake the engine cover to fit . I WANT MY ENGINE COVER
Old Aug 26, 2008 | 04:31 PM
gary c's Avatar
According to your signature you already have the 5/16" spacer installed, so
why are you asking questions about other size spacers/covers?
Gary
Old Aug 26, 2008 | 04:36 PM
Da_ReD_G's Avatar
LOL gez man can a buddy try something different. IDK man if there are more gains in a different spacer then hey why not give it a shot. if the 1/2'' is better than the 5/16'' overall then why not switch
Old Aug 26, 2008 | 04:50 PM
twin001's Avatar
To be honest with you, you won't feel the gains over the 5/16" spacer. Stick with what you have. If you want to try something different that will give you more power then get a nitrous setup, or get a UTEC or Osiris.....based on your mods in your sig.
Old Aug 26, 2008 | 04:53 PM
Da_ReD_G's Avatar
VERY true i been debating how much wet or dry or even if i should spray. iw as told that vq should stay wet
Old Aug 26, 2008 | 04:57 PM
twin001's Avatar
my350z.com has a few threads on nitrous, you should check that out.
Old Aug 26, 2008 | 06:12 PM
SteveBlake's Avatar
Yea if you're gonna do nitrous only get a wet kit but you'll also need a purge kit and maybe a bottle warmer. But if you do go with nitrous you NEED to get your car tuned for it!
But just FYI, i have a Turbo XS utec and the gains are NIGHT and DAY.
Old Aug 27, 2008 | 01:35 AM
Skaterbasist's Avatar
Retired SuperMod
nope
We can't possibly explain it any better than MD's very own website. You should try reading it when you have the time.
I would suggest the 5/16 spacer. But it seems that you already have it
