race pipes or high flow cats ?
Old Sep 10, 2008 | 04:12 PM
VEEG35.0's Avatar
what do u guys think cuz i need to get one or the other o ya my stock cats r burned out
Old Sep 10, 2008 | 04:20 PM
twin001's Avatar
Test pipes will be cheaper but louder and prone to rasp. Hi-flow cats will be more expensive and generally sound better. You "should" make more HP with test pipes but with an NA motor you may not even notice a difference. Also, your exhaust will smell with test pipes.
Check out the XYZ pipe from Motordyne, it's modular so you can switch out as necessary.
Old Sep 10, 2008 | 04:22 PM
iamericgee's Avatar
get the hfcats it will sound better !
Old Sep 10, 2008 | 04:35 PM
booger's Avatar
Ive tried them all . Even some HFC's will rasp [ highest flowing ones ] go with the cats unless your Turbo'ed
Old Sep 10, 2008 | 04:49 PM
VEEG35.0's Avatar
im not turbo and dont want rasp sound
Old Sep 10, 2008 | 05:00 PM
VEEG35.0's Avatar
will hf cats pass smog ?
Old Sep 10, 2008 | 05:05 PM
dmitriylm's Avatar
Just go with high flow cats over a test pipe if those are your two options.
Old Sep 11, 2008 | 04:10 PM
fbpem1's Avatar
i would say keep it factory theres no point in putting that garbage on your car unless your pushing some serious power (forced induction) that motor was designed with those cats in mind just my .02
Old Sep 11, 2008 | 05:01 PM
GooberGman's Avatar
If yours are burned out already knock all the rest of the crap out of them with a large screwdriver and a mallet and reinstall. cost zero & problem solved.
Old Sep 11, 2008 | 05:06 PM
dmitriylm's Avatar
The real question is why are they burned out. Stock cats can usually take quite a few miles unless something is wrong with your engine tuning.
Old Sep 11, 2008 | 05:12 PM
DaveB's Avatar
Your cats are not "burned out". If they were failing, usually a brick comes loose, they'd be covered under the emissions equipment warranty which I believe is good for 9 years/90K miles.
Old Sep 11, 2008 | 06:49 PM
w33ps's Avatar
Hfc!
Old Sep 11, 2008 | 09:44 PM
Hydrazine's Avatar
I like test pipes. They make good gains.
With the XYZ pipe, you can still use test pipes and hook up the XYZ catalytic converter.
It will give you better gains than regular HFC's.
StreetStandard
Exhaust-Vendor
11
Jan 12, 2016 03:21 PM
Th611
Oct 27, 2015 03:48 PM
jbelf23
Forced Induction
Oct 24, 2015 12:32 PM
linedr89
Aug 17, 2015 05:11 PM
Team STILLEN
Aug 10, 2015 08:17 PM
