Changing resonator = Decrease Back Pressure??
Old Sep 24, 2008 | 03:00 PM
Jeff92se's Avatar
Red Card Crew
Understanding and using correct terminology helps the OP understand the question at hand. Does it not?
Old Sep 25, 2008 | 02:53 AM
cremaster's Avatar
^^ yes, it does. but the bottom line is:
"will messing w/ the resonator ever cause you to lose power?"
that's all i really wanted to know.
Old Oct 31, 2008 | 11:35 PM
frosticlez's Avatar
who really cares about how much back preasure is created or lost, the real difference is the sound it makes, duh!
does the resonator with the stock exhaust change the tone of the exhaust note, how so?
Old Nov 1, 2008 | 11:53 PM
VQ Dawg's Avatar
The answer to this question is yes, no and maybe. There is no ONE answer to this question. In general, altering a resonator will affect the overall power curve of an engine. I can't fully explain this because it would take me too long. For those who really want to understand why this is, research the terms "quarter wave tube" and "helmholtz resonator." These two theories are what exhaust system designs are based off of (at least the more sophisticated ones.)
In your case, removing the resonator likely has little to no affect on peak power. What likely did change is that it probably slightly lowered low end power and added a little mid range due to a shift in the resonant frequency of the pressure waves in the system.
Old Nov 3, 2008 | 11:57 AM
Q45tech's Avatar
Historically backpressure vs dyno measurements have show each 1.0 psi to be worth ~~ 2.0 HP.
Measure in front of what you want to change at 6,000 rpm [under roadload]and see how much is possible..............even a straight pipe will not drop to zero but you should be able to halve the backpressure with MAXIMAL noise.
Old Nov 3, 2008 | 12:04 PM
cremaster's Avatar
thanks for the responses to my super old thread lol but really, some of the responses were helpful.
Old Nov 3, 2008 | 08:17 PM
OCG35's Avatar
Farting is velocity, holding it in is back pressure (well, stomach pressure, but it’s from being held back)...
So, I'm pretty sure that clears everything up.
* I just thought I'd post something stupid and not relevant but has same retarded metaphor - since I've been seeing it in other threads lately... I'm pretty sure it’s a requirement at least once a month on Driver.
jsimonk
Dec 22, 2023 03:49 PM
ghost_g35
Aug 7, 2015 10:31 AM
RedBaronK
Jul 27, 2015 06:25 PM
apintojr
Jul 23, 2015 10:52 AM
